Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-18-2009, 06:54 PM
brock is on a distinguished road
Clear Polycarbonate Face
All,
I am looking for a quote for 10 pieces.
This part needs to be made from 0.25" clear polycarbonate. The finished product must remain clear except for the edges and holes as this is a face for a pressurized case - The user needs to be able to see through this part.
http://brockbr.com/case/caseface.zip
I've included an STL and a SLDPRT file in the zip file. If another format is needed, let me know.
Thanks!
b.
Old 08-18-2009, 11:22 PM
Toymanf is on a distinguished road
Do you specifically require polycarbonate? I can quote it for you in clear cast acrylic if that will work.
Frank Rodgers
Old 08-19-2009, 07:15 AM
Frank Rodgers
Frank,
Given the case will be used at pressures nearing 370psi, the face material needs to be very, very strong. I'm under the impression that acrylic wouldn't be as strong as the polycarbonate.
Please correct me if I'm wrong.
b.
Old 08-19-2009, 08:58 AM
CLOSED
I've accepted a bid from a shop in NH.
Total bids: 6
Variance on bid price: 100% - A single bid was half the price of the rest, whereas the rest where within +/- $0.50 per piece.
Thanks to everyone who bid. I have more parts coming.
b.
Old 08-19-2009, 10:39 AM
And in case anyone is interested, I did not go with the lowest bid. I actually went with the highest bid due to having a conversation with the shop via telephone.
b.
Polycarbonate forming thorsgaard Vacuum forming, Thermoforming Etc 8 09-21-2007 05:22 PM
Hardened Polycarbonate pointless General Material Machining Solutions 5 07-17-2007 09:00 PM
RFQ....Acrylic or Polycarbonate dvsmac Employment Opportunity 6 05-10-2007 08:58 PM
Drilling Lexan / Polycarbonate Fadal Error Glass, Plastic and Stone 2 07-06-2006 01:23 PM
angular contact bearings face to face?? powerfade DIY-CNC Router Table Machines 2 06-18-2005 11:01 PM
