Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-17-2009, 10:40 AM
pava1 is on a distinguished road
Contract programmer needed
We have a single project that we require the services of a Programmer/Operator for a Thermwood CNC router experienced with manually programming. We have the hand held controller, but not enough experience for this complicated part. The services would be required on site in Ontario Canada. Thank you.
Old 06-17-2009, 11:00 AM
Boots is on a distinguished road
First of all.... which Model Thermwood is it ? Does it have a floppy disk or CD ROM Drive ? If so this part can be programmed and sent to you for input into the machine. If you don't have a drawing and all you have is a sample of the actual part then perhaps the hand held controller is the way to program here. I am have run and programmed for the Turret Model with twin 5 X 5 tables. 91000 control and OS2 system.
Old 06-17-2009, 12:37 PM
The Thermwood is a C67DT. It does have a 3-1/2" floppy drive but you are correct, the part will need to be programmed from a sample using the hand held controller by an experienced operator. The machine was installed here 06-25-98 and is a twin table model.
Old 06-17-2009, 01:29 PM
I could program this for you but I live in Maine (Central) and it's a little bit far, but programming with the hand held is pretty straight forward. I would lay the part on the table (s) and trace it with an outline. Then put a series of cross lines to that out line and take the cordinates of the intersections using arc's and lines to define the outline when you hit enter on the controller it inputs the cordinates into the machine and generates the NC code needed. Put a pin type laser into the spindle held by a collet and this will allow you to drive the machine around well above the table without having to raise and lower the head as you would have to do if you had a pointed tool in there instead. I use a 5/8 dia pin laser and tape the button on to do this.
Old 06-23-2009, 08:26 AM
D_I_S is on a distinguished road
I sent you a pm, I look forward to talking with you.
Old 06-23-2009, 08:52 AM
CSinnovation is on a distinguished road
pava1,
Control System Innovators Corp. is a engineering controls and automation group specializing in Siemens CNC equipment and programming. We have a great deal of experience with many different CNCs and could potentially be able to solve your programmer needs.
We are located out of Burlington, ON. Hopefully it is local to you and if possible we could set up a visit to your facility to take a look.
Take a look at our website for a bit more info:
www.csinnovation.com
Michael (905) 681-1580
michaele@csinnovation.com
Please do not hesitate to give me a call or send an email.
Seeking Contract Surfcam Programmer HiTech Employment Opportunity 13 10-26-2009 03:19 PM
Job Opening Contract CAM programmer in Atlanta GA chet Employment Opportunity 0 12-23-2008 07:37 AM
Contract Mastercam Programmer Wanted smecher Employment Opportunity 1 08-01-2008 08:20 AM
Contract Programmer kklaver Employment Opportunity 1 04-26-2008 01:32 PM
Contract foam cutting needed 43220 CNC Wire Foam Cutter Machines 4 04-01-2008 12:05 PM
