| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I have designed a kayak and would like the panels cut from (4) 3mm 3'x7' door skins and (1) 5.2mm 4'x8' plywood sheets. I have AutoCAD files or can provide DXF. I have already laid out the panels on the sheets because I would like to use different colored woods for different parts of the kayak. I can provide the material if necessary. The 5.2mm plywood would be birch veneer on one side (I am open to other options). For the door skins, I would like to find out what veneers are available. Here is an image to give you an idea of what it looks like. The different background colors represent different wood facings. ![]() I have some space left so I may still add some parts. I am located in the Santa Rosa area (northern California). Also, I'm interested in prices for two of each and one of each. If you are using a DIY router, please be sure it cuts accurately. The more accurate, the easier it is to built the kayak. THANKS!
__________________ "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944) |
| I didn't see the image of what it would look like. I would be interested in quoting. You can send the image or information to aminear@wyomingwireless.com |
| hello i'm from rohnert park just down the road from santa rosa. there is a router place in the industrial area of RP i think its called "the cnc shop"? if i drive by in the next couple of days i'll pass on the info to you. i would cut it for you but im booked for a few months (projects for the wife and for Rancho cotatie HS) |
| Cris Edit: I googled and found their address - they are just over a mile away! THANKS!!!
__________________ "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944) Last edited by HawkJET; 06-04-2009 at 10:38 PM. |
| Thanks to all who responded! I have awarded the job to a TheCNCshop.
| Hi Hawk. Any chance you would share that file? Looks like something I'd like to try routing. Pike My Equipment: Gerber Edge II www.gspinc.com Gerber envision Vortech Router www.vortechcnc.com Roland Versacamm www.rolanddg.com My Software: Corel X3 Vectric Vcarve Pro www.vectric.com Adobe Illustrator & Photoshop Mach www.machsupport.com Gerber Omega |
| I have updated the design and it uses four 4'x8' sheets of plywood (instead of 4 3'x7' and 1 4'x8'). One sheet is 5.2mm thick and three are 3mm. If you are wanting to build a kayak, there is a bit more to it than just having the panels. I don't even know how well everything will fit yet. Plus there are doublers and other reinforcements that are not obvious. It would take some knowledge and experience to make it without have any instructions.
__________________ Architectural - Prototype - Modeling - Mold / FrogMill - ScanTech 3D Laser - ArtCam Pro Foam - Composites - Hardwood (www.dragonxtreme.com) |
Yeah, I am the same way... but I'm sure you know that not everyone is. I'm just making sure that there are no expectations.
#10
| Hey if you don't mind sharing the file, I'd love to give it a shot. All I have to lose is a few sheets of plywood.. Im doing a lot of work for customers and have been trying to think of a project for "fun".. Thanks!! My Equipment: Gerber Edge II www.gspinc.com Gerber envision Vortech Router www.vortechcnc.com Roland Versacamm www.rolanddg.com My Software: Corel X3 Vectric Vcarve Pro www.vectric.com Adobe Illustrator & Photoshop Mach www.machsupport.com Gerber Omega |
#11
Where are you located? What kind of plywood will you use? Here are some photo albums of a couple kayaks being built: http://www.westcoastpaddler.com/buil...s.php?album=15 http://www.westcoastpaddler.com/buil...s.php?album=17 The sheets look like this: ![]() The blue shaded one is 5.2mm thick and the rest are 3mm. If the plywood is too thick, it will be difficult to bend and warp the panels as needed. They need to be cut out and pieced together like this: ![]() The panels shown at the top and bottom are the right and left pieces of the bottom of the hull. They are 5.2mm thick. It should look something like this: ![]() Where should I send the files?
| 4'x8' DIY CNC Router Questions | SouthForkSam | DIY-CNC Router Table Machines | 13 | 10-12-2010 12:00 PM |
| Need to build a 4'x8' CNC router fast! | robertmonroe | Joes CNC Model 2006 | 9 | 11-27-2008 09:10 AM |
| Z axis length for 4'x8' router mill | wcarrothers | DIY-CNC Router Table Machines | 10 | 08-20-2006 08:29 PM |
| 4'X8' router needed! Simple foam project. Phoenix, AZ! | kburn | Employment Opportunity | 1 | 02-20-2006 07:31 AM |
| Machine Tool Camp 4'x8' VS Cad Cut CNC 4'x8' Router | Trimix | DIY-CNC Router Table Machines | 6 | 12-18-2003 01:49 PM |
