Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-27-2005, 09:02 AM
seansear is on a distinguished road
Need drawing converted
I am looking for someone who can convert an Autocad drawing from acad2000 to R14.
Bruce
Bruce
Old 01-27-2005, 09:16 AM
ger21's Avatar
Can you upload it here?
Old 01-27-2005, 09:24 AM
How about this
1 dwg
Bruce
Old 01-27-2005, 09:26 AM
ger21's Avatar
Here you go.
Old 01-27-2005, 09:39 AM
That was quick
That was quick. Could you do one other thing and convert it from metric to standard (english,imperial) What ever you want to call it. Decimals is fine.
Really appreciate it.
Bruce
Bruce
Old 01-27-2005, 10:00 AM
ger21's Avatar
just select everything, and use the scale command. for the scale factor, enter:
(/ 1 25.4)
make sure you include the parenthesis
You can copy and paste that into the command line.
Need 2 files converted from .max to .stl seansear Employment Opportunity 4 05-16-2005 10:53 AM
need Autocad .dwg file converted RcCNC Mastercam 12 04-29-2005 05:10 PM
Problem with drawing? or CAM? CNC Darren General CNC (Mill and Lathe) Control Software (NC) 13 01-05-2005 12:30 PM
Need drawing converted from .max to .3ds seansear Employment Opportunity 1 01-03-2005 12:51 PM
Easiest 3D drawing program NeoMiller Autodesk Software (Autocad, Inventor etc) 1 10-23-2003 06:56 AM
