Results 1 to 7 of 7
Thread: CNC Milled alu prototype
    May 2009
    Hungary
    Hi
    I need 2 pieces of this for prototype, if turns out good we can continue with a 20-50 pc. serie.
    ALU 6061 or similar.
    Part needs to be anodized, I'd be glad if you do that, but I can anodize also.
    Original model is in ProE WF4 format.
    Has to be shipped to Hungary, so I prefer a manufacturer within the EU.
    IGES file
    picture 1
    picture 2
    Size: 60x45.5x30 mm. Tolerance: +- 0.1 mm
    Thanks in advance;;;
    Nov 2005
    I'm a US Rep for Jinmeng Precision Machinery. We can quote this part, if you would like. We can machine and deliver component within 7-10 business days. But we are outside the EU, please let me know if we can quote your RFQ.
    Lindsey Wack
    May 2009
    Hungary
    shotgun_mann: PM sent.
    Jul 2005
    PM Sent
    May 2006
    Denmark
    You are aware that some of the part is not possible to machine on a 3 axis machine with standard tools. Inside on the side where the fins are placed there is a spot that is not possible to mill either from the top nor the bottom
    Also the piece has a lot of fancy roundings that makes machining a lot more dificult/time consuming. If price is an issue, you may want to turn down on all those CAD features :-) For example, the rounded fins calls for an additional setup and the chamfering on the fins definitely calls for 5 axis
    Im using WF4 too, if you send me the file i can show you what i mean. Also i can give you a RFQ, shipping from Denmark to Hungary cant be that expensive
    May 2009
    Hungary
    Quote Originally Posted by Guldberg View Post
    You're absolutely right! I just made some quick final modifications, and that's what happens if I work in a hurry.
    Thanks for the correction!
    bugfix version 1.1
    May 2009
    Hungary
    closed
    1. First milled PCB
      By Jason Marsha in forum PCB milling
      Last Post: 11-18-2008, 09:49 PM
    2. Milled Out A Hovertank
      By John Bear Ross in forum Benchtop Machines
      Last Post: 03-07-2008, 04:14 PM
    3. I need some slots milled in some 14 ga SS.
      By Jeff Wohlt in forum Employment Opportunity
      Last Post: 10-31-2007, 06:02 PM
    4. RFQ Al plate/milled
      By roninB4 in forum Employment Opportunity
      Last Post: 09-07-2006, 02:23 PM
    5. Never milled but have a project
      By mikesativa in forum General Metalwork Discussion
      Last Post: 03-22-2006, 02:24 PM
