Results 1 to 5 of 5
Thread: RFQ: 30 pcs 0.5" HDPE, 11" Ø
    Jan 2008
    I have an order for 10 units. Each unit gets 1 ea part. So I need 10, 10, and 10.
    Pdf's are attached. I've called out a flatness tolerance... I won't actually be measuring that, but its my way of saying that the material needs to be reasonably flat.
    Please quote material and labor (service) separately.
    Due date of assembled units to my customer is 6/1/09. So I would need these parts approx 5/14 to 5/21/09.
    I'm located in Philadelphia.
    thank you!
    Attached Thumbnails Attached Thumbnails RFQ: 30 pcs 0.5" HDPE, 11" Ø-tt11_base.pdf   RFQ: 30 pcs 0.5" HDPE, 11" Ø-tt11_lid.pdf   RFQ: 30 pcs 0.5" HDPE, 11" Ø-tt11_mouth.pdf
    Apr 2007
    SENT YOU A P.M. ,THANKS, Joe @ Tuson Enterprises
    Tuson enterprises
    Jan 2008
    Thanks everyone for quoting.
    I've pretty much received enough quotes to make a choice.
    Some FAQs:
    Regarding OD finish and my request for lack of "indents," this is pretty much covered by my OD tolerance: ±0.015". In other words, if there is an indent that is more that 0.015" deep, then the OD is out of tolerance. A hose-clamp will be applied to the OD.
    Regarding the thickness tolerance, "stock" is fine. Lets say ±0.040". Flatness is the important issue.
    thanks!
    Aug 2007
    PM sent
    Oct 2008
    China
    do you need create injection mold for the parts ?
    1. Need A Quote- Looking for someone in Edmonton to cnc router some 3/4"mdf and HDPE
      By Xnaron in forum Employment Opportunity
      Last Post: 10-04-2011, 05:54 PM
    2. Has anybody used "Boatboard" (marine HDPE) before?
      By CanSir in forum Joes CNC Model 2006
      Last Post: 07-13-2008, 07:30 AM
    3. Has anyone looked at the "JET" or "Shop Fox" manual machines?
      By boosted in forum General Metal Working Machines
      Last Post: 03-04-2007, 10:33 PM
    4. Vertical system "jerks" and "bangs"??
      By REVCAM_Bob in forum Servo Motors and Drives
      Last Post: 06-12-2006, 10:09 AM
    5. Add "View New Posts" to "Main Menu"
      By Mr.Chips in forum Forum Questions or Problems
      Last Post: 04-21-2004, 11:54 PM
