| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
First Piece (Part # 001) Material - 6061 Aluminum Units - Inches Tolerances - +/- 0.01" (Except the 8mm hole & 1/2-20 RH thread, need to be exact) Turn Around - Sooner is good, but cheaper is best. Quantity - 1 piece |
| Second Piece (Part # 002) Material - 6061 Aluminum Units - Inches Tolerances - +/- 0.01" (Except the 3/16 hole & 1/2-20 RH, need to be exact) Turn Around - Sooner is good, but cheaper is best. Quantity - 1 piece Explanations - For the #6-32 thread, I will be using a total of four set screws, to hold in a slide-fit 3/16 shaft. ![]() |
| On part one how close must the 1/2-20 thread be to 1.1250 shoulder? Off the shelf thread inserts will get it with .062 with out grinding it down. Either that or how about some thread relief, a .430 diameter under cut at the shoulder ?? wide. I am assuming part 1 & 2 mate? How long are you leaving this quote open? Target price? |
I will leave this open for 1 week from today. Target Price? Not sure. I can't see these costing too much. Thanks. |
| RFQ - Small aluminum parts | JeffEmbracedDC | Employment Opportunity | 15 | 11-19-2008 09:45 AM |
| What Homemade CNC for small RC aluminum parts? | PAPE | Parts for Radio Control Models | 4 | 01-26-2008 07:38 AM |
| RFQ - Aluminum Parts - small job | F500 | Employment Opportunity | 8 | 06-08-2007 03:30 PM |
| How hard is it to get into CNC Machining small aluminum parts? | GreasyMidget | General Metalwork Discussion | 4 | 10-12-2006 09:20 PM |
| RFQ - small mild steel turned and drilled parts | mcmmach | Employment Opportunity | 8 | 07-28-2005 09:37 PM |
