Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 04-16-2009, 07:29 AM
millman52's Avatar
millman52 is on a distinguished road
plasma cut part
Please find attached a .dwg & .dxf drawing of part. It's a simple washer, cut from clean A36 plate. 3/16 or 7ga. (use most cost effitient material)
Part must be free of dross & burs
OD will be fine at +/- .020 ID must fit over 1 1/2" CRR bar stock for welding.
Bid quantitys (price per part) in what you can nest to 4' X 4' sheet. I will concider full 4' X 8' sheet quantity if it will create a significate price decrease.
email bid to: mullinsmachining@hotmail.com
If it works.....Don't fix it!
Old 04-17-2009, 07:20 AM
jimcolt is on a distinguished road
Part quote
Millman,
You can fit 175 of these washers on a 4 x4 sheet....probably can get an extra row on a 4 x 8....so could likely get 363 on a 4 x 8.
Very simple part....will cut very well with plasma.
I sent you a PM.
Jim
Old 04-21-2009, 02:27 PM
Jparks54 is on a distinguished road
E-mail sent
Thanks Joe
Need Help!- Need a favor. STL converted to part file or solidworks part file. Cmzwirner Solidworks 3 12-11-2008 07:45 AM
Verify Cut part to Design part. CaseyCAM NCPlot G-Code editor / backplotter 0 11-01-2008 09:22 PM
Newbie- Part holding and milling 3D part on 2.5D Mill? john_t_h General Metalwork Discussion 6 03-15-2008 06:35 AM
RFQ 6 copies, milled part, 9 copies turned part sswitaj Employment Opportunity 5 01-31-2008 01:42 PM
Missing steps on just a certain part of the part ZipSnipe Stepper Motors and Drives 5 01-02-2008 01:40 PM
