Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 04-12-2009, 10:31 PM
AuroraDrvr is on a distinguished road
RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled)
Material - Steel (does not matter, what ever is cheapest. A36?)
Units - Centimeters
Quantity - 1 (Possible random reoccurring orders of various sizes if allowable)
Turn Around - ASAP
Explanations - On the green perforated lines, there will need to be 4 drilled and tapped holes for M3 (.5mm pitch). 4 Holes per green line, at 90º separation. Staggered 45º between lines. The chamfers you see are .5mm @ 45º
There was trouble viewing my last RFQ files so I will post these on this thread as JPEG images. Two with, one without dimensions. Please PM me any Quotes, or questions. I will try and explain them better.
Old 04-12-2009, 11:08 PM
besc is on a distinguished road
PM Sent.
Old 04-13-2009, 06:25 AM
snovak240 is on a distinguished road
PM sent
Old 04-13-2009, 12:20 PM
joesz is on a distinguished road
Tolerance
Not possible to provide an accurate quote without some sort of tolerance to work by. That part at +/- .010 would be about $180 bucks the same part at +/-.0001 would be about $1200 bucks. You have the numbers out to 4 decimal places , industry standard would mean that is a very close tolerance part, in most cases 4 place decimals are +/-.001 or less.
Tolerance may not be critical and in that case the cost goes way down try to remember every decimal point is another dollar sign.
Old 04-13-2009, 02:41 PM
Rally's Avatar
Rally is on a distinguished road
PM Sent
All comments made are my opinion!
Old 04-14-2009, 01:12 AM
Sorry guys, just realized that this design will not work. I will redesign and repost a new thread.
Thank you to those who did quote.
Drilled & Tapped Precision Shafting justCNCit Mechanical Calculations/Engineering Design 3 12-23-2008 05:56 PM
RFQ 34 - Small manual job - Offset turned and cross drilled hardened locking pin InspirationTool Employment Opportunity 9 09-12-2006 07:26 AM
RFQ: 1" Steel Round Drilled on lathe js530 Employment Opportunity 0 06-24-2006 10:11 PM
RFQ - small mild steel turned and drilled parts mcmmach Employment Opportunity 8 07-28-2005 09:37 PM
Are sherlines drilled and tapped?? BriteHarry Mini Lathe 1 10-14-2004 07:36 PM
