Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 04-11-2009, 11:49 PM
millman52's Avatar
millman52 is on a distinguished road
80 Stainless Brackets
Quantity 80
May be produced using any process that will maintain listed tolerance
Parts must be ready for assembly on an OEM application without additional deburring or finishing. Discoloration from a plasma process ok.
Attached is a .dwg V14 AutoCAD file of part.
It has been requested I add a .dxf file it is also V14 AutoCAD
If it works.....Don't fix it!
Last edited by millman52; 04-12-2009 at 10:42 AM. Reason: Request for file in .dxf format
Old 04-12-2009, 09:25 AM
besc is on a distinguished road
PM Sent.
Old 04-12-2009, 10:24 AM
millman52's Avatar
Originally Posted by besc View Post
PM Sent.
Replied
Old 04-13-2009, 04:55 PM
jimcolt is on a distinguished road
Plasma Cut Stainless part
Here's a pic of the part cut with a Hypertherm Powermax45 on a PlasmaCam table. Time to import .dxf file from the file below....5 seconds, apply cut path and lead ins...about 20 seconds. Adjust cut speed, torch height and kerf width for 3/16" stainless...about 15 seconds. Turn on plasma...place 3/16" sheet on slats, turn on Torit fume control....about 30 seconds. Hit cut start button....cut was complete in less than 25 seconds. Here is picture....holes are exactly .5" at the bottom and are about .006" big at the top.
This is 3/16" thick 304 stainless cut with air plasma....there is a brownish oxide layer on the cut edges...and a slight taper on the cut face. A $100k high definition plasma could do better...but this is a pretty nice part!
Jim
brackets Runner4404spd Employment Opportunity 0 07-27-2006 05:41 AM
Angled Brackets JohnG DIY-CNC Router Table Machines 12 05-19-2006 04:10 PM
RFW steel brackets AustinT Employment Opportunity 2 05-10-2006 10:47 PM
Stainless brackets needed 18GA ty1295 Employment Opportunity 1 01-26-2006 11:13 AM
No square brackets at machine ghyman G-Code Programing 0 04-12-2005 02:05 PM
