Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-10-2009, 11:15 AM
dantm is on a distinguished road
RFQ - two-part support
Thank you to everybody who responded to my last RFQ.
Currently, one of my students has designed a support for a small antenna project; it consists of 2 parts which should be relatively simple except for one feature on each part:
Part "outer" is the bigger (blue) box is approx. 3 x 5" and has a narrow, internal channel which is required by design to have 'square' corners -- i.e. as tight radius as possible. The dimensions of this channel are 0.148 x 0.074".
Part "inner" is the smaller (yellow) piece, fits inside, and is fastened to the "outer" piece. This has a feature of a 'rectangular' cut-out that is required to be with as square corners as possible. The dimensions of that cutout are also 0.148 x 0.074".
Do you guys suggest any techniques that can allow these to be made? Is anybody here interested in this project?
Many thanks and best regards,
/Dan
Old 03-10-2009, 11:17 AM
Old 03-10-2009, 11:22 AM
Old 03-10-2009, 03:40 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I would EDM the square corner pockets.
Expensive, but you gotta do what you gotta do.
www.integratedmechanical.ca
Old 03-10-2009, 06:02 PM
How much does that add to a job (say in this case)?
Also, I have 3D files (IGES/DXF) if anybody is interested in looking at these, thank you!
Old 03-11-2009, 07:59 AM
DareBee's Avatar
Depends on the tolerance and surface finish needed.
If specs are reasonable maybe $300 CDN
Old 03-11-2009, 08:23 AM
Is this pricing for the entire part or were you just mentioning the EDM cost alone? In both cases, it's pretty steep ;-)
Old 03-11-2009, 11:13 AM
DareBee's Avatar
EDM work only.
$950 for the job depending on what "high precision center hole" means (if it needs to be more accurate than a Reamer double the price).
it's pretty steep
No it isn't.
This is also why I don't bother to quote anything here.
Old 03-11-2009, 11:41 AM
Interesting; that is good information - thank you!
Also please pardon my ignorance as I am not a mechanical engineer nor have an understanding of what milling or EDM work involves and the time/material/etc. consumed.
/Dan
Old 03-11-2009, 03:14 PM
DareBee's Avatar
No problem - we all started at ground zero at some point in time
  #11   Ban this user!
Old 03-12-2009, 02:48 PM
benji2505 is on a distinguished road
tolerances
if you request tolerances better than 0.001" means you are willing to pay big bucks. Question was why your student needs this tolerance. Most of the s.c. high tech parts do not need it.
  #12   Ban this user!
Old 03-14-2009, 03:50 PM
levelzero is on a distinguished road
Why does the channel have to have square corners? Is it acceptable to do something like the attached image?
Need Help!- Need a favor. STL converted to part file or solidworks part file. Cmzwirner Solidworks 3 12-11-2008 07:45 AM
Verify Cut part to Design part. CaseyCAM NCPlot G-Code editor / backplotter 0 11-01-2008 09:22 PM
Newbie- Part holding and milling 3D part on 2.5D Mill? john_t_h General Metalwork Discussion 6 03-15-2008 06:35 AM
Missing steps on just a certain part of the part ZipSnipe Stepper Motors and Drives 5 01-02-2008 01:40 PM
APT Support cimlinc General CNC (Mill and Lathe) Control Software (NC) 0 10-24-2006 12:01 PM
