Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 12-21-2004, 05:15 AM
SonicBlast is on a distinguished road
RFQ Mod1 Gears
I am looking to get some gear made for testing, and maybe later on to order in bulk. The gears I need have to be Mod1 gears, with a thick/strong hub and atleast a 4mm set screw. The width of the teeth should be 1cm wide, along with a .5cm wide hub, so top to bottom the gear will stand 1.5cm. The ammout of teeth are 15, 16, 17, 18.
Later on I will be looking at getting some mod1 60t spur gears made as well.
Old 01-15-2005, 01:54 AM
Bigfoot1 is on a distinguished road
re: gears
Sonic Blast ,you did not specify the type of material you were looking for with these gears , if you're still looking for a supplier let me know.
Old 01-15-2005, 02:02 AM
Two types of metal....
Stainless and Hardened steel.
The following tooth sizes seem to be more what we will need now 12t, 14t, 13t, 15t, 16t, 18t.
Thanks for the reply.
Old 01-15-2005, 10:10 AM
Kmed is on a distinguished road
Have you looked into what stock drive offers for blanks? I will see if I might have some mod1 stock lying around, but most is 1.5. If you go to online catalog-gears-spurgears-check the metric bubble- then select the module. Looks like they have 12-14-15-16-18 tooth gears.
http://www.sdp-si.com/
Old 01-15-2005, 01:50 PM
Cold Fusion is on a distinguished road
Sonicblast, I bet you're going to use these for RC cars. Did you already contact Jamie of Starluck RC? He's got a few of these in stock already...
Proud owner of a Series II Bridgeport.
Internal Gears??? itsme General Metalwork Discussion 11 02-11-2005 03:21 PM
custom gears studysession General Metalwork Discussion 18 12-01-2004 06:36 AM
Posting RFQ CNCadmin RFQ (Request for Quote). 0 11-03-2004 11:57 PM
RFQ closed - scale model machined auto wheels needed joemartins Employment Opportunity 9 10-27-2004 09:16 AM
Timing belts, gears, and ratios samualt DIY-CNC Router Table Machines 11 12-19-2003 08:09 PM
