Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-15-2009, 04:49 PM
alliedm is on a distinguished road
CNC machinist / programmer position - CT
We are looking for a CNC machinist / programmer for our job shop. We have expanded our milling capacity and need extra help in the area of programming, setting up, and running 3-5 axis VMC's. Currently using mastercam 9 but most likely going to X this year. This position also requires that you be proficient with 3D cad software (preferably Pro/E) as many of the jobs you would be working on are model only (no 2d drawings provided by customer). Please contact me if interested, but please only if you actually have the ability to take a drawing or model through to finished product with little or no assistance. Shop is located in Newington, CT.
We are not interested in contract programming. We need someone in house to physically set up machines and run parts on top of programming... The typical milling projects are of low quantities and require new programming and setups 1-3 times/week
Old 02-27-2009, 07:16 AM
cncengg07 is on a distinguished road
hai
i am mani, indian. now i am working in nigeria
Old 02-27-2009, 08:11 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Howdy ?
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 03-16-2009, 05:17 AM
simonboy1982 is on a distinguished road
Apply
Dear Mr/Mrs/Ms,
I would like to apply for the job.
I have Mechanical Engineer Bachelors degree(2004) . I have 3 years experience with CNC machines, specially with mill machines, but I have no problems with lathes. I know G-codes, and Hedenhain codes too. I can work alone. I can work with CAM softwares, and also with SolidEdge and AutoCAD.
I think I work hard, I can find out solution for problems. I worked in the USA as a CNC operator 1th and 2th shift, so work time can be in any shift.
Nowdays I work as a designer and a cnc programmer. I worked with metals(stainless steel, aluminium(with ERGAL too), plastics, graphit etc.). I Have experience with 3axes and 4axes mill machines (G-codes, Heidenhain).
I would like to strart to work as soon as possible. I'm living and working now in Hungary, but ready to leave right now.
Thank you for your time!
Best Regadrs,
Laszlo Simon
lazlosimon@hotmail.com
+36 20-264 7988
Job Opening CNC Machinist/Programmer - Connecticut lbi17 Employment Opportunity 1 02-08-2009 01:57 PM
Job Opening CNC MACHINIST / PROGRAMMER J.BREWER Employment Opportunity 0 08-20-2008 07:49 AM
machinist/programmer 1METALHEAD Daewoo/Doosan 9 03-06-2008 01:46 PM
CNC Programmer/Machinist schiada96 Employment Opportunity 2 10-03-2007 07:36 AM
Programmer Position JIMMY Employment Opportunity 0 11-13-2006 03:33 PM
