Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-13-2009, 09:19 PM
rubberdown is on a distinguished road
Looking for any laser cutting shops in or near Ontario to quote on a job!
Please let me know if you are anywhere in or near Ontario and if you can cut 1/4" thick mild steel with a laser. I will e-mail DXF files for what I need quoted once I know if you are in the required area and can help me.
Qty will be small on first run of parts, but it can increase. By small, I mean 4 or 8 of the first item, and 8 or 16 of the second item, if everything looks good and is dimensionally correct, it could be higher qty's. The parts are just over 12" around and circular in shape x 1/4" thick with some holes and other shapes laser cut into them.
Thanks.
Old 02-25-2009, 11:04 AM
Thank you for your interest, i should have replied sooner, I have found a supplier.
Old 03-06-2009, 05:19 PM
LaserDon's Avatar
LaserDon is on a distinguished road
We are in the Detroit area.
Belleville Michigan
We have 2 Mitsubishi Lasers with automation
We can cut up to 1" plate Mild Steel
1/4 plate not a problem..
http://www.abmyrlaser.com
Senior CNC Programmer
Mitsubishi Laser ML3718Plus
IT - Network Support
IT - Help Desk
Need A Quote- Waterjet / Laser quote needed. twicecustom Employment Opportunity 1 11-14-2008 07:07 PM
laser or waterjet quote please metlcutr55 Employment Opportunity 2 05-27-2008 10:29 AM
Laser/Waterjet Cutting - Quote Request wwendorf Employment Opportunity 5 03-27-2008 02:06 PM
.125 thick material quote on waterjet or laser cut mcraig79 Employment Opportunity 0 07-07-2007 08:53 PM
Looking For SS Laser Cutting Quote lal19541 Employment Opportunity 0 06-28-2006 03:51 PM
