Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-25-2009, 09:32 AM
BespokeCars is on a distinguished road
Pirce for light pod please
I need these light pods milling in the cheapest possible way.
Picture attached for sizes in MM
I'm also looking for someone who can do all my company work so looking to build up a good relationship here.
Old 01-25-2009, 11:38 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
You're going to need to post an IGS or STP file for anybody to give you any kind of idea. Is that all one piece? Including that ring (I assume it's a headlight)? I don't even think that is produceable by machining. It looks like you're thinking of an injection molded part but wanting a low production solution.
In my opinion, you don't want to know what a machined solution will cost (it'll be thousands of dollars).
I think if you really need that shape, you're going to have to carve it out of foam, cover the foam in body filler and make a master plug. Pull a fiberglass splash off of that to make a mold, then produce fiberglass parts from the mold.
Greg
Old 01-25-2009, 12:44 PM
Matt@RFR is on a distinguished road
Like Greg said, that's going to be one expensive mother. Just at a glance (that thing is around 19" long!), count on $400-$500 in material alone, 8 hours of programming (and a lot of head scratching), and another 6-10 hours of machine time. That's for ONE PART.
Are you prepared to spend $3000* on a set of these? If not, please let us know so noone spends a ton of time quoting the thing for nothing. If you are, please post an STL file with as much information as you can think of, like:
-material alloy
-surface finish
-largest allowable fillet on all inside corners (for ball nose endmills)...the bigger
the better
-overall and specific tolerances
-required lead time
-quantity, this order
-quantity, future orders if applicable
Greg, I make parts sort of like this for high end hot rod builders, and you'd be blown away by how much they're willing to spend to have something that nobody else does. One that pops into my mind is a $600 hood latch. It's fun work too, so everybody wins.
*This is NOT a quote!!
Old 01-25-2009, 01:03 PM
Yeah, Matt, I don't doubt that there are people who will pay seemingly crazy prices for custom parts. Some people 'get it' and don't mind paying what some of these things will cost.
I got to thinking about another RFQ on here the other night (the throttle body). I'll bet that if I quoted it for just the material and the cutters that would get used up in that job, it would be too high.
As soon as I bought my machine, friends came out of the woodwork wanting custom wheels. When I told them what the billets were going to cost, they thought I was lying to them. They wonder why I don't have 'billet everything' on my personal vehicles. They just don't understand what cutters and material really cost.
Greg
Old 01-26-2009, 03:14 AM
levelzero is on a distinguished road
There are a few ways to make these depending on the quantity needed, unfortunately milling will not be the cheapest. You can make a mold and have them done in fiberglass, or you could cut individual pieces and weld it together. After a little finishing work, once installed you wouldn't be able to tell it was a welded assembly.
Old 01-27-2009, 06:26 AM
skykash2000 is on a distinguished road
Hi could you please email me the drawing to melvinchan@kct.com.sg
i try to give you the best price.
Old 01-27-2009, 07:21 AM
dpryor is on a distinguished road
How many are you going to need total? 2? 20? 2,000?
That will definitely affect how you approach the manufacturing of it.
Doug Pryor
David Wolfe Design, Inc.
Akron, OH
www.davidwolfedesign.com
depryor@davidwolfedesign.com
a ring of 200 Led Lights to light up? light source render? Rich05 Solidworks 6 10-25-2008 06:16 PM
Spectra light and Light machine owners have ? ZipSnipe Benchtop Machines 11 07-18-2008 09:52 PM
320 fault Light Ed Williams Gecko Drives 0 02-05-2008 09:28 PM
Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal SCG11762 General Metal Working Machines 2 08-27-2007 08:08 AM
Light Transformer plexer General Electronics Discussion 5 05-09-2006 08:01 PM
