| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Can it be fabed like the one in the pic or do you want it to be one peice of billet it would take more machine time and material mat +chips=cost may be necessory to weld then finish bore the boss and the final Id. to elemanate distorten in the o ring bore for the sensor and make a finish cut on the I.D. a sampel of the sensor or the aplacation and I could get a sample to measure Thank's Kevin |
| Welding them together will be way cheaper, but anything can be done. Another option would be to have the two parts bolt together with a oring between them, I've done this in the past for intake manifold adapters and it works well even under boost. |
| saleCNC laser engraving machine and CNC woodworking machine | zhangrui1588 | Laser Engraving & Cutting Machines | 3 | 05-08-2011 04:54 PM |
| Which steel/alloy is most suitable for spindles and spindle housings? | romihs | Mechanical Calculations/Engineering Design | 22 | 12-18-2008 06:07 PM |
| Deep Groove Taig machine would it be a good starter machine | Fritzie15 | Taig Mills & Lathes | 0 | 09-20-2007 10:37 PM |
| Microwave Housings Rendered in Blender3d | Rekd | CNCzone Club House | 4 | 05-23-2006 09:20 PM |
