| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Hi I have a small job. We need about 5 parts produced as described in the attached file. Most likely there will be more to come, maybe fifty. Also might have some variations on this part with different dimensions. Check out the pdf. Also I can send edrawing if that is helpful. Tolerance is 0.1mm. The part should be produced from aluminum, whatever type you feel is best for your process. It could be produced in several parts and welded together, or cut out of a single piece of 1/4" plate, whatever is easiest/cheapest given the small volume. Some of the parts will be needed in Thailand, and some in the United States, so no particular preference for location. Thanks, David Last edited by hyperdyne; 01-18-2009 at 03:24 PM. Reason: file missing a page |
| David, are you sure you need that .1mm (.004") tolerance? Specifically, the 320mm dimension between the legs. If it's welded, that tolerance will not be realistic, and even worse if the parts are bent. Which leaves us with machining the entire thing, which will be very expensive. My suggestion, if it's at all possible, is to relax the tolerance on atleast that one dimension so it can be formed on a press brake after machining. I think that's the least expensive way to make this part. |
| Thin aluminum bending | LaserImage | Bending, Forging,Extrusion... | 10 | 10-28-2008 12:59 PM |
| Problem- aluminum extrusion bending | skary[WTF] | Bending, Forging,Extrusion... | 1 | 08-15-2008 02:06 PM |
| RFQ Aluminum bending into c channel | seansear | Employment Opportunity | 1 | 07-28-2008 04:56 PM |
| Bending Aluminum Bar | energyforce | Bending, Forging,Extrusion... | 1 | 04-12-2006 12:09 AM |
| Bending small aluminum rod | Twmaster | Bending, Forging,Extrusion... | 9 | 08-06-2004 08:50 PM |
