| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Hi guys; Sadly, this is only a small job, but maybe someone has a couple of hours open that they'd like to fill. This is a mounting bracket for circuit cards, .25 x .25 x 1.65, with 4 threaded 4-40 holes. Tolerances are nominal. Material is not critical, aluminum or steel, any alloy. Break all edges and flush chips so that part does not any shed any latent tiny chips onto circuit boards. Typical clean mill finish without any dramatic tool marks is fine. I need 72 pieces, in 2 weeks or less. Drawing is attached. You can contact me directly at sswitaj (at) aol (dot) com - Steve |
| Relatively straight forward part, the only real problem I see is that if the end holes break through the traverse holes it would compromise the threads slightly. Would standard 0.25" stock be fine? This would save a fair bit of machining. |
| If the job is still open, I would like to quote it. Is material cost to be in the quote? Thanks daledavisjr@hotmail.com |
| Need Help!- servo motor brackets | lyncomputer | Want To Buy...Need help! | 6 | 02-18-2009 09:34 PM |
| brackets | Runner4404spd | Employment Opportunity | 0 | 07-27-2006 06:41 AM |
| Angled Brackets | JohnG | DIY-CNC Router Table Machines | 12 | 05-19-2006 05:10 PM |
| RFW steel brackets | AustinT | Employment Opportunity | 2 | 05-10-2006 11:47 PM |
| Bridgeport X Y brackets and pullys | Fabric8r | Bridgeport and Hardinge Mills | 6 | 12-31-2004 11:00 AM |
