Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-11-2009, 02:10 AM
marshall1 is on a distinguished road
Need a Small Quantity of Acrylic Sheet Cut
I need 6 Plates of 1/2" Clear Acrylic Sheet cut and drilled to the specs on the attached file. I also need it to be within .001" accuracy. I can be contacted at abalkenhol@gmail.com
Old 01-11-2009, 11:53 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
Are you supplying the plastic? If not, you need to be more specific about the plastic. And are you sure you want 0.001" tolerance? Is that position, hole diameters, overall size or all of the above? That's pretty tight for a piece of plastic and you'll pay for it.
Greg
Old 01-11-2009, 10:40 PM
I can supply the plastic, it is 1/2" clear cast acrylic such as Acrylite Acrylic Sheet. The design in the file is the entire part with holes drilled in it. So the end product would be a 6.5" square plate with holes drilled in it. The tolerance could be .01" if need be. I used to have access to a Gerber cnc router that would hold these tolerances but I don't have access any more. The laser engravers that I have used in the past seem like they would do the job as well.
Old 01-12-2009, 08:04 AM
Cebby's Avatar
Cebby is on a distinguished road
Does it have to be CNC, or would you consider waterjet?
www.TOOLandFAB.com
www.ControlledCutting.com
Old 01-12-2009, 07:44 PM
Water jet would be just fine. I'm not picky about how it's cut as long as its accurate.
Any innovative ideas for cutting acrylic flat sheet into discs? SRT Mike General Metalwork Discussion 6 08-17-2008 09:17 PM
small quantity plastic source? zcases Glass, Plastic and Stone 7 01-02-2007 12:20 PM
where to get small quantity of material? pp-TG General Metalwork Discussion 3 12-08-2006 08:56 AM
Looking for small, simple, manual lathe work, any quantity sanddrag Employment Opportunity 2 08-01-2006 09:31 PM
Images Milled on Plastic/Acrylic Sheet High Seas Glass, Plastic and Stone 6 06-10-2005 12:44 PM
