Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 12-30-2008, 09:33 AM
cdlenterprises is on a distinguished road
Turning & Milling job
Looking for a quote on two rods. The parts are identical save for the material - one is 6061 and the other is 300 series stainless. I'm not fussy about what type of 300 stainless is used. The parts will be high polished and used for show vs strength or corrosion resistance so what ever machines the best will work. Qty's are 25, 50 , & 100. Quote only the machining for both parts.
ID:	72532   Click image for larger version
I don't know much about anything but I know a little about everything....
Old 12-31-2008, 03:52 PM
doughtybrian is on a distinguished road
P M has been sent
Thanks Brian
Brian's Machine & Powdercoat
Old 01-02-2009, 12:55 AM
Dualkit is on a distinguished road
I take it you are going to ship the material to the vendor? Then you should list
your location if time and shipping costs are an issue.
CNC Turning and Milling for Hire kcarlin Employment Opportunity 4 12-29-2008 01:48 PM
Newbie- turning in the milling machine? Numb Nut Benchtop Machines 12 10-23-2008 05:31 PM
Cooling for Milling / Turning - When is oil appropriate? ewest General Metalwork Discussion 4 07-24-2007 08:16 AM
Aluminum (turning/milling) impact Employment Opportunity 5 06-27-2007 03:39 PM
