| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
REQUEST FOR QUOTE REQUEST GENERATED DATE JOB REFERENCE 12/30/08 BRS59 To whom it may concern, Please quote the following machine work request; 1” OD round brass bar to be machined (bored / drilled / reamed) clear through to provide a centered bore of .85” ID Finished pieces to be 12” length with clean 90% angles both ends. Interior finish to be smooth and bright. Material to be 360 brass or brass alloy with similar machineability. Initial quantity to be 100 pieces. Near future commitments of 500 to 1000 pcs. per order probable. Please quote this job both with materials provided, and also machining only. Also advise lead time I look forward to hearing from you regarding the above . Sincerely, Stephen Parkinson Medical Construction Consultants, Inc. SMPARKINSON@HOTMAIL.COM |
| Some suggestions: You need to list tolerances. If the bore diameter has to be held particularly tight, it's different than just drilling. Does the outside (1") need to be finished or is the 'as wrought' mill finish acceptable? Ground finish is available but it seems to be about double the price. The 'mill finish' exterior can be turned but finish and tolerance need to be specified. Are you sure you want brass? It's pretty expensive as a material. There are a number of manufacturers that will make you custom aluminum extrusions. If the tolerances permit, you could buy the extrusion with the right inside and outside dimensions. While we're at it, McMaster sells brass tubing, 1" outside, 0.87" inside (very close to what you want), in precut, 12" lengths for $22 each: item 7782T271. If that's not what you're looking for, six-foot lengths of 1" round are $130 ($26 per part--you'll only get 5 parts per bar when saw kerf eats up some of the material). Costs are going to be high. Anyway, just some thoughts that others might need and some things you might consider to reduce the costs for yourself.
__________________ Greg |
| Need A Quote- CNC Lathe Work | Exoray | Employment Opportunity | 17 | 12-28-2008 04:12 PM |
| Need RFQ - Lathe work | ozturbo | Employment Opportunity | 7 | 07-11-2008 02:00 PM |
| Newbie- Weld Brass to Brass | piratesover40 | Welding, Brazing, Soldering, Sealing | 3 | 03-03-2008 07:02 PM |
| Need more work for cnc lathe | R&B | General Metalwork Discussion | 7 | 10-15-2006 11:53 AM |
| CNC lathe work | Crazy Phantom | Employment Opportunity | 8 | 02-05-2006 11:42 PM |
