Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 12-22-2008, 08:01 AM
Harshwardhan's Avatar
Harshwardhan is on a distinguished road
Arrow For a 4-axis CNC job in India
Please quote in Indian Rupees for 2 numbers of this 4-axis CNC job. (This is NOT exactly a leadscrew. At one point, the pitch angle changes to zero and then back again to the normal pitch angle. The profile changes too.
IGES file is attached. The material is 202, 204, 302 or 304 stainless steel. Good finish in the profile is important. Length of the job is 935.6mm and profiled section is 818mm long. The job needs a machining center with a dividing head axis.
Please treat this as urgent.
Harshwardhan Gupta.
You can directly respond at harsh@neubauplan.com
Tags
4-axis cnc machining
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 08:15 PM
Hi, greetings from India creahub CNCzone Club House 1 08-08-2008 03:06 AM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 02:54 PM
CNC Router: made in India contactirfu CNC Wood Router Project Log 65 03-24-2008 03:32 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 03:58 PM
