Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-23-2008, 07:13 PM
Runner4404spd is on a distinguished road
aluminum cap 4pcs required
i need 4 pcs of the below cap. basically its an aluminum shell that is a center cap for a wheel. the part can either be turned manually if someone is so inclined or by cnc and i require 4 pcs. i will award this no later than 9/29/08 hopefully to someone on this board. parts will need to be delivered to 48312 zipcode. please quote completed job plus shipping. cap does not need to be polished but a smooth turned surface is required.
email or pm with any questions
Old 09-24-2008, 06:17 PM
RedGTZ's Avatar
RedGTZ is on a distinguished road
Arrow
You have a PM about this work
Thank you!
Info required jamiefegan General Metalwork Discussion 0 06-16-2008 04:52 PM
Some Assembly required... On right now bryanrabb WoodWorking 1 01-09-2008 09:51 AM
Assistence required Smitty911 Machine Problems, Solutions , Wireless DNC, serial port 0 03-22-2007 11:02 PM
aluminum mould required SNOOPER666999 Parts for Radio Control Models 0 02-11-2007 01:18 PM
Help required...Surfaces zedzero Mastercam 2 01-13-2007 03:18 PM
