Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-20-2008, 03:33 PM
timmydabull is on a distinguished road
RFQ spline broaching
RFQ spline broaching part file attached
i will be providing material 3.5x1.140 6061
DWG file is attached
thank you
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 09-20-2008, 03:42 PM
here is a jpeg of the part,will send files to any who request and furnish email address.
there will be 10 parts in this order.
Old 09-21-2008, 05:55 PM
makinoman is on a distinguished road
I am not sure that you will find someone who has a broach to do that. And a broaching tool for that would most likely run you alot of money. Hard to tell the thickness of that part, but you can probably expect the broach for that to be no less than $1100. Although I could be wrong, I wish you best of luck in finding someone who can do that for you.
Old 09-23-2008, 09:17 PM
the part is 1 inch thick.
i called slater tool and they havent gotten back to us on whether they can supply a broach fir this.
$1100 is right on the money for the tool and toolholder.
how do you reccomend i cut this part.
allready obtained quote for EDM $30 per part does this sound correct for a part 1 inch thick 3.5 inch chain.
Old 09-24-2008, 12:29 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Yep, I was going to say EDM, that's the way to go for low production.
Old 09-24-2008, 05:52 AM
NC Cams is on a distinguished road
Or someone who has a Bridgeport broaching head lying around.
WE have one but havent' used it enough to help out with any level of expertise.
Go with the EDM....
Old 09-24-2008, 07:19 AM
I'm not too familiar with edm but it sounds like that would be your best bet, other than that whoever has a broaching machine will work the price of the tooling and fixturing into the quote and that is gonna push the price upwards. Especially if this is just for 10 parts. We have broaching machines here where I work and the broaches are not cheap. I'm curious though is it a press fit for the spline? The reason that I am asking is because if you could live with a radius instead of sharp corners you could probably put the spline in there yourself with an endmill and save yourself the outside processing.
See picture below, if you could have something like this then a .200 endmill and 4th axis capabilities would be all you need.
Old 09-25-2008, 12:08 PM
Makinoman,it is not a press fit more of a transmission shaft,the loadis against the face of the spline and not the radius.
i was thinking along those lines as well,i think i will try it.
thanks for all the advice guys
if all else fails maybe i can edm some tool steel to make a form to square the corners in a press,after machining.
Old 09-29-2008, 08:34 AM
peter@slater is on a distinguished road
re: Splinie Broach
This form is too large for rotary broaching. Once I got the CAD file open, it looks like the tooth height is about .080. The maximum tooth height we recommend for rotary broaching a spline is about .030, and that's with ideal depth, material and thrust.
Old 09-30-2008, 07:25 PM
Peter i received your email,thank you for taking the time to look at our file,turns out sometimes the obvious solution is the simplest one,as makinoman pointed out it will work out nicely to extend the radius on the outside root diameter of the part.
1 operation in house.
thank you
tim
ps i have been in the mindset as a consumer for so long that i always think first "where can i find this" that i sometimes forget i need to be in the frame of mind "how do i make this with what i have available"
  #11   Ban this user!
Old 10-01-2008, 10:20 PM
Makinoman,that geometry that you suggested worked mint.
thank you for your assistance.
  #12   Ban this user!
Old 10-02-2008, 09:51 AM
Hey not a problem, glad I could help.
Rotary Broaching rhino General Metalwork Discussion 10 09-16-2011 01:15 PM
Broaching on CNC Mill? tkoden General Metal Working Machines 14 09-16-2011 01:08 PM
Which press for broaching? Arnaudb General Metalwork Discussion 3 03-29-2008 08:19 PM
spline help,mc9.1 GRANDPA Mastercam 10 03-10-2007 06:00 AM
Broaching advice Al_The_Man General Metalwork Discussion 9 12-19-2006 05:03 AM
