Results 1 to 4 of 4
Thread: RFO (request for opinion)
    Nov 2004
    Greetings,
    Need an opinion of the cost for this part. It is a firing pin for a pistol. I need to tweak the measurements a bit but a ballpark figure on what each piece would cost is what I need.
    I also need advice on what I need to provide on my end to keep the cost down. ie; .dxf format etc.
    Thanks in advance
    Chandler
    Attached Thumbnails Attached Thumbnails RFO (request for opinion)-davis_fp.jpg
    Gold Member
    Dec 2004
    Newtown, CT, USA
    I believe you are missing some dimensions.
    How many do you need?
    What material? Does it need to be hardened after machining?
    Tolerances?
    Specify the radius of each corner. Especially the maximum radius of each inside corner.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Nov 2004
    I've updated the image with some dimensions that were missing.
    I need 25.
    No hardening.
    I'll post more info.
    If someone can make these parts for a reasonable amount I'll provide a sample part with the order.
    Nov 2008
    Is this RFQ still open?
  1. No opinion!
    By bfreesebfreese in forum Commercial CNC Wood Routers
    Last Post: 02-05-2007, 11:28 AM
  2. Your Opinion Please....
    By jaybee101 in forum Benchtop Machines
    Last Post: 02-02-2007, 05:20 PM
  3. Need opinion
    By diemaker1 in forum General Metalwork Discussion
    Last Post: 06-09-2006, 08:37 PM
  4. Your Opinion Please
    By Barefooter in forum General CAM Discussion
    Last Post: 09-06-2005, 09:58 AM
  5. Need Opinion
    By Builder in forum Bridgeport and Hardinge Mills
    Last Post: 10-26-2004, 06:13 PM
