Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-01-2008, 10:20 AM
fossilworld is on a distinguished road
3 Foam Logo Signs
We need three logo signs all the same. Width to be 6'6" each. Two are to be on 6" foam with 3" relief for the circle background and 6" relief for the dinosaur and the lettering. One is to be mounted on 5/8" MDF plywood finished on the sides with the same Polyurethane so it needs to be on 5" of foam with 2" relief for the circle background and 5" relief for the dinosaur and the lettering. Want to see the dinosaur be done with smoothed 3D rather than as a flat relief. The second line of lettering will be a separate piece. Finish to be in Polyurea or Polyurethane coating in the colors as shown. Will be mounted outdoors. We will stucco finish 2 of our signs so 1" of relief will be lost. Our logo requires one last revision that should be done in the next couple of days. File can be a PDF file with layers or can be provided in other layered formats you specify. Price to be FOB your factory.
Old 09-03-2008, 07:16 AM
dpryor is on a distinguished road
We would be very interested in quoting your project. You mentioned that you have other data formats available. Do you have any CAD formats available (i.e. DXF, DWG, IGES)? These would just save time. We can still work with the PDF if necessary. We have a large 5-axis router (and another one on the way) that would be perfect for this kind of work.
Doug Pryor
David Wolfe Design, Inc.
Akron, OH
www.davidwolfedesign.com
depryor@davidwolfedesign.com
Old 09-03-2008, 07:50 AM
Response
no files in DXW or DFG. The original art was done in Adobe Illustrator with layers for the separate elements.
Old 09-03-2008, 07:58 AM
In that case, send us the PDF and we will see what we can do.
Thanks,
Doug Pryor
Akron, OH
Old 09-03-2008, 08:17 AM
Response
Cannot do that yet as one change is stil to come. I should ahve it tonight or in the morning and will post it then, thanks for your interest.
Old 09-03-2008, 09:36 PM
File
Here is a link to the .AI file and the PDF file
http://fossil-world.com/logo/discovery-center.ai
http://fossil-world.com/logo/discovery-center.pdf
Need Help!- Carving Signs Sam A BobCad-Cam 2 05-04-2008 09:01 PM
Painting wooden signs? abomb55076 WoodWorking 26 08-07-2007 10:39 PM
RFQ Billet superman signs clarq_kent Employment Opportunity 21 05-26-2007 11:40 AM
wood signs Pugster WoodWorking 1 07-07-2006 11:21 PM
Top Ten Signs wms CNCzone Club House 19 06-21-2003 07:04 PM
