Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-03-2008, 07:46 PM
dahui's Avatar
dahui is on a distinguished road
Lightbulb Proposed sticky for RFQ file format!
1) Always post a PDF!
2) If it's a quote for a CNC job incude BOTH a PDF and DXF (not just DXF)
3) please oh please don't zip that file!
PDF is the solution: to all file sharing. If you don't have acrobat reader...what is wrong with you? You have a computer right? The PDF allows people (anyone/everyone) to see the print and decide if they want to bother. Click on file, view part. No more steps in between.
The DXF will allow the CNC folks to estimate cutting time but isn't really needed otherwise. I have software to view DXF's but it's a hassle to wait for the program to load every time and if I'm cranky I don't even look at them.
Zipping of files: If your print drawing is more than 2MB then...oh wait converting to PDF has reduced your source file size so that's not a problem. It's the 90's man, why zip a file? Efficiency? The time lost in saving and unzipping and locating the zipped file and organizing my folder structure and fragmenting my hard drive and downloading unknown content and defragmenting my hard drive and opening the file only to find it will not open properly because it was zipped in the first place...is less than efficient.
How do you make a PDF if you don't have Acrobat?
http://createpdf.adobe.com/
http://www.cutepdf.com/
https://www.pdfonline.com/convert_pdf.asp
Old 08-03-2008, 08:17 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
A dxf is almost a waste of time for estimating as well. If the job is no more complicated then 2.5d work (which is all a dxf is good for) just stick with the pdf.
To generate a pdf (for those that don't think they can) download and install a tiny (free) program called CutePDF.
If the job requires more than 2.5d machining give us an iges and a parasolid AS WELL AS a fully DIMENSIONED and TOLERANCED print in PDF format.
My.02 is done now.
www.integratedmechanical.ca
Old 08-04-2008, 10:54 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
DareBee, you are a saint!
I've been looking for something like that PDF generator for ages, but every time I need it I haven't got the time to go looking!
Many, many thanks man, worked a treat.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 08-05-2008, 11:42 AM
dahui's Avatar
Wink
Don't forget to check the three links I left for PDF generators. I'm also vying for my sainthood!
I forgot to enable a poll, so maybe if people can just vote.
The point wasn't to cover all quoting situations, but to give the most basic format and make things easy for everyone.
Dimensions and tolerances would certainly be helpful. For those that aren't familiar with tolerances, if you can give your machinist friends some idea of the application then they can probably figure out what range of precision is needed and help specify.
Old 08-11-2008, 11:36 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Just google BullZip PDF Printer. All you do is click print, and instead of selecting your normal printer, select the BullZip PDF printer and it saves what ever your looking at in .pdf format. Works on every program, even your CAD programs.
MC
Old 08-12-2008, 07:19 AM
DareBee's Avatar
MC
Exactly the same as CutePDF
Old 08-12-2008, 10:06 AM
ImanCarrot's Avatar
Yep! as DArBee said, Cute thingy installed quick, easy and is now a "printer" on anything I want to print- if you ask it to print to the Cute thingy it'll ask you what file name... simple as a blonde bimbo at last orders! easy peasy! thanks mate!
Old 08-12-2008, 01:30 PM
DareBee's Avatar
New Avatar for you - eh - Iman
Old 08-13-2008, 03:07 AM
ImanCarrot's Avatar
Heh yep, wanted to put an animated one in but it was too big.
anyone have the DSTV file format? ABC123 General CAM Discussion 21 07-28-2009 11:38 AM
DSTV file format? ABC123 General CAM Discussion 7 01-16-2009 05:37 AM
File format conversion for fee wanted octathorpe Employment Opportunity 17 06-22-2008 09:00 PM
Understanding file format osaris Mazak, Mitsubishi, Mazatrol 3 04-01-2007 07:38 PM
?Best? transportable CAD file format? vladdy General CAM Discussion 4 11-08-2005 08:40 AM
