| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I need a few pieces done at this time (2x). I also want the person to do more pieces in the next 5 weeks. The pieces i need now is for my X axis. The pieces i need is the blue part in picture nr.1 (x2). Dimensions you will find in picture nr.3 (or in the layout.pdf). The thickness of the piece can be between 20mm - 25,4mm. Cheers Jan Last edited by Jan Rune; 08-03-2008 at 10:18 PM. |
| That is probably a good idea. I just have to admit that this is my first mechanical drawing ever. I have no skills in this area what so ever. In the center hole a 20mm ballscrew is going through. So 1" is giving me enough space to work with. I have been reading alot 'bout geometric tolerances the last hours, but i have still nothing to come up with. So please anyone that answering this quote, give me a hint about the accuracy you can do... This might look a bit amateur-ish. And yes it is ![]() Forresten Guldberg: Er dette noe du kan gjøre? |
| Hi will be glad to help manufacture oneoff parts in Alu.. have the setup and worked extensively on alu... if you need help . accu_spark@indiatimes.com ; altitudetechnologies@indiatimes.com |
| How is this part attached to the extrusion and bearing blocks? In some ways this may determine what kind of tolerance you need on the parts in terms of precision fit-up. I can't remember the metric equivilants at the moment but +/- .005" and +/-.001" are pretty standard for tolerances. Of course there are things like +0.0"/-.001" etc. A sheet of paper is about .003" just for reference. The more precise tolerancing you need the more expensive it will be. |
| My plan is to drill/tap some holes in the manufactured part. Then screw it together with some M4 & M6 screws. Okey, i guess the tolerance im going for should be about +/- .01 mm then (roughly .005"). Thanks for the info Dahui! That did help me out alot... |
| Jeg har udstyret men ikke materialerne eller tiden:-) 0.01mm is pretty close tolerances. Do you really need that? As far as i can see you need to screw the two linear bearings into the top of the part, and the part itself to the bracket at the bottom. The only critical tolerance then, is the width of the part on the top. .005" is roughly 0.13mm by the way :-) |
#10
Haha, greit det. Skjønner at dette ikke er ett stort oppdrag som hvem som helst tar på seg heller ![]()
| Rockcliff aluminium parts | fenton | Rockcliff Machine | 3 | 04-16-2009 05:35 AM |
| My Bucket Full of Aluminium Parts | Harpye | DIY-CNC Router Table Machines | 65 | 10-22-2008 02:09 AM |
| Machining aluminium or steel machine parts - Australia (Melbourne) | RASPNC | Australia, New Zealand Club house | 5 | 04-06-2008 11:21 PM |
| NOT easy Aluminium parts RFQ | dvsmac | Employment Opportunity | 4 | 01-21-2008 09:26 PM |
| Ovality issues for aluminium parts | Viru | General Metalwork Discussion | 7 | 04-04-2007 10:40 AM |
