Results 1 to 6 of 6
Thread: Control Panel Cut out
    Jul 2008
    Im have no skill in the machine shop, no tools and a small budget and im looking for a quote to have some holes cut in a thin pieces of steel (lid from a computer enclose). I need to mount some surplus joysticks(4), switchs(20), segment LCDs(8), handles, ect. its about 10inches by 16inches. i would just try to wing it, but i would butcher it. im located in orlando, fl. you can email me at scruffyjones48 at hotmail
    Dec 2003
    If all the holes are round, I would look at beg/borrow/rent a power hand drill and buy a couple of drill bits and a Uni-bit for the larger holes.
    Also a hammer and centre punch.
    The cost would be less than someone doing it, if you get stuck.
    Jul 2008
    Ya i was hoping to have it look somewhat professional. thats why i hope to outsource the work.
    ckm
    ckm is offline
    Too many projects
    Jun 2006
    Quote Originally Posted by scruffyjones48 View Post
    www.frontpanelexpress.com
    www.protocase.com
    Not terribly cheap, but the results are perfect.
    HTH,
    Chris.
    List of parts sources for CNC builders - http://www.CNCsources.net
    Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
    Dec 2003
    Usually the the professional effect is on the panel overlay, (it can hide all kinds of blemishes )
    If you have a CAD package, one method I use is to draw it up in CAD and get a local engraver to reverse engrave all the legends etc on common Lamacoid, this way you get a professional look fairly cheap, the reverse engrave technique allows muli-colour legends etc, and is cheaper than Lexan, which is usually reserved for quantity orders, rather than one-off.
    Registered dahui's Avatar
    Dec 2005
    If you can accept an acrylic face or wood face I can cut it with a CNC laser. Of course that can be painted and finished. I also have a CNC vinyl cutter for labeling.
    I'm actually a professional product designer so if you can give me a sense of where you are going with this I could make suggestions regarding material and process. If you are interesed of course. Is this a one off or a prototype?
    Also, it will be important to know if the holes are round or square since a true 90 degree corner i basically impossible for a CNC mill or router. Laser would be great but I doubt if you can find a high power machine to cut metal that will be cheap. Plasma is an option but I can't really say without knowing more details. Feel free to PM me.
    1. T32 Control Panel Lock up
      By bean79au in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 07-13-2008, 05:59 AM
    2. Problem- Versalaser Control Panel
      By Vice in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-22-2008, 04:15 PM
    3. CNC Control Panel and Pendant Functions
      By SCzEngrgGroup in forum Benchtop Machines
      Last Post: 12-07-2007, 11:31 AM
    4. My DIY control panel
      By DennisCNC in forum CNCzone Club House
      Last Post: 10-02-2006, 11:24 PM
    5. Building my control panel
      By ChrisJ in forum General Electronics Discussion
      Last Post: 03-02-2005, 09:09 PM
