Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-20-2008, 08:59 PM
Maritime is on a distinguished road
RQF on Aluminum Machining
Hello, this is my first post. I'm interested in having a product machined in aluminum. I have the design of a product that was originally made out of acrylic or lexan sheet. I would like the product made from aluminum. I have .dcd and .dwg files. My specifics are that the base is made from 1/2 inch aluminum and that the wheels extend approx. 1/4 inch through the base. The wheel mount can either be a thick disc with the axle bolt through it, or a thinner disk and the wheel mounted on brackets. Perhaps looking at the plans would be helpful. The .jpg was added to illustrate anothe wheel mounting option. The wheels that I will be using are 66.5mm in length.
Gareth
Old 07-21-2008, 07:24 AM
KTD1 is on a distinguished road
I'm interested in quoting this for you but I'm not clear on which parts you would like me to make.
Please give me a call.
Max Kulpinski
(269) 651-4279
www.kulpinskitool.com
Old 07-21-2008, 01:14 PM
protman16 is on a distinguished road
Gareth,
What quantities are you looking for and how often?
Thanks,
Trevor
Old 07-25-2008, 05:00 PM
mactec54 is on a distinguished road
Hi Maritime
Can you do the files in DXF
Mactec54
Machining aluminum honeycomb Making chips Composites, Exotic Metals etc 4 06-03-2008 11:23 AM
Machining Aluminum Bronze home-tek General Material Machining Solutions 8 12-29-2006 11:06 PM
Machining 2219-t4 aluminum scottwally General Metalwork Discussion 2 06-18-2005 10:53 PM
Machining L168 aluminum laamar General Metalwork Discussion 2 01-30-2005 04:31 AM
machining aluminum castings donj1 General Metalwork Discussion 9 11-05-2004 06:12 AM
