Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-16-2008, 11:27 AM
lashbeck is on a distinguished road
CNC Programmer - Appleton WI 7471
This is a Temp to Hire position
1st shift postion 7:30am to 4:00 pm with some OT available
Establishing work instructions (routing) for new projects
Developing fixturing and work-holding for manufacturing processes
Programming CNC code
Continuous improvement of process
Create the work instructions (routing) information to accurately reflect the processes to be used in manufacturing the parts.
Create the set-up sheets to be used by operators to consistently set-up the job.
Write/coordinate writing the CNC code for each CNC operation.
Working with quality, create the inspection instructions for new parts.
Monitor the first production runs
to assure that the set-up sheet is accurate and the set-up time is correct.
to verify process control and that quoted production rates can be achieved.
If process capability or rates cannot be achieved, take the necessary corrective steps to achieve them.
If all reasonable steps have been taken and process capability and/or production rates cannot be achieved, bring the situation to the attention of management.
Work with the production manager to develop ongoing process capability and productivity action steps and assist in implementing the steps. Monitor the results.
Working with CNC mills and lathes
Fanuc controls-G & M code
Some Mitsubishi controls
Working with Solidworks, Feature Cam and Master Cam
Proficient in the use of Techsoft CAM software.
Proficient in the use of PC software such as Microsoft Excel, Access and Word.
Proficient and experienced in the CNC machining processes.
Looking for CNC Programmer/Set-up Melissa Lawson Employment Opportunity 3 04-10-2008 08:42 AM
How does one become a programmer? ToppDog General CAM Discussion 8 06-02-2007 12:14 AM
Looking for CNC programmer swa Employment Opportunity 3 04-08-2007 07:18 PM
Looking for CNC Programmer JosieLuebesmier Employment Opportunity 0 02-23-2006 12:28 PM
CNC Programmer bigsmac Employment Opportunity 0 10-27-2005 05:23 PM
