| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Hi everyone, I'm looking to have a simple hub/spoke/rim design machined out of 6061-T6 3.25" rod stock. Please see attached picture. Designed this in Rhino, so I can export to any format necessary. Please bear with me -- this is my first machining project ever, so I know nothing at all, starting with the cost of machining such things. (Perhaps CNC is overkill for this? Alternatives?) Outer diameter: 8.255cm (3.25") Inner diameter: 8cm Height: 2.5cm I can provide the stock material. My idea is just to drill out the inside diameter, cut center circle, and then cut the spoke holes. This is a purely aesthetic piece, so most anything can be changed. For example, if it were to be easier/cheaper to machine if the spokes were less vertically thick, that's just fine. I'm a poor college student, and as silly as it might sound, this project is for romance! For both of those reasons, my budget is tight and desire for someone to take pity is high =) Thanks for reading. Last edited by cromas; 07-07-2008 at 08:33 PM. Reason: capitalization fix...oops |
| Thanks for the several replies. Some clarifications:
That's a little presumptous seeing as how none of us really know the dimensions of those features. What might be more appropriate is, "the bigger the better". Make the radii as big as you can without impacting your vision. Also, for future reference, you don't want to run an 1/8" endmill into a corner with a 1/16" radius. The endmill will stop for an instant, unload, then start in another direction causing, at worst chatter and at best a noticable overrun. |
Again, thanks for bearing with my amateur mistakes and questions. I very much appreciate all of the advice I've already received. |
| Came across this looking for ideas or places to find raw aluminum... But I had to read down... Now the question is ... Did someone machine this for them,,,, and if so how did it come out...and work out in the romance Dept.... ha |
| 3/16 Aluminum - POOR CUT QUALITY | zeoncomp | CNC Plasma and Waterjet Machines | 12 | 08-01-2010 11:10 AM |
| Need A Quote- RFQ: Small (3"x5"x1/2") part from dimensioned drawings in Aluminum or stainless | octathorpe | Employment Opportunity | 6 | 06-23-2008 07:14 PM |
| Poor/Desperate student needs information help about posts | MrG | Post Processors for MC | 23 | 06-18-2008 03:24 PM |
| RFQ - Small CNCed aluminum part, batch of 50 | Enraged | Employment Opportunity | 29 | 01-21-2007 07:26 PM |
| RFQ - Small production run of aluminum part - European Machine Shops Only Please | jayd | Employment Opportunity | 2 | 04-30-2005 05:34 AM |
