Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-21-2008, 11:22 AM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
Mach3 CNC Full System Integrator services avail.
Mach3 CNC Full System Integrator services:
Greetings,
I would like to offer my services to do any Regular or High End Mach3 Control
System(s) for your company. My name is Scott Shafer, ("PoppaBear", from the Mach Support forum). I am a Mach3 Controls integrator, my company, S S SYSTEMS, LLC is listed on the Mach3 Support site by Art Fenerty.
Services offered:
• Custom Mach3 Screens, both regular and Flash Screens. This includes live "Movie" style Help topics, at the CNC control.
• VB Wizards, Macro's, and Macro-pumps.
• Advanced I/O, including Mod-bus/Brains, PLC's and other Mod-bus devices, this includes Serial and TCP, (advanced CNC Controls, multiple analog overrides, custom physical button interfacing).
• TCP Mod-bus up to 2048 points of I/O (discrete or 16 bit register).
• Serial Mod-bus up to 256 points of I/O (Pendants, Physical CNC control interface).
• Advanced AC and DC Servo’s, Stepper, VFD Drives interfacing with Mach for complete parameter monitoring and control. Any Drive system that takes Step and direction or Analog (requires converter). Sure Servo, Danaher, Kol Morgan, Pac-Sci, others.
• External motion Board interfacing of: Smooth Stepper, Galil
• Standard Para-ports and full Panels.
• Mod-bus control of: Plasma/Laser/Water Jet/welder/torch control (for devices that have CNC control interfacing). This includes interfacing with Other Com models like Can-bus, Profi-bus, and others through intermediary PLC's.
• C++ plug-ins available
• Complete Machine Design, Build, or Retrofit any type of CNC/Industrial Machine, ATC's, Pallet Changers, DNC, Pick and Place Robotic Loaders/Unloaders/conveyor systems, and Machine Cells.
• Typical Machine control, and Machine builds: Routers (standard, Laser, Plasma, water jet), Mills 3-6 axis with ATC's, Pallet changers, Lathes 2-4 Axis with ATC's, Bar Pullers, Drop Spindles, Foam 2-4 axis, Wire EDM 2-4 Axis, 2-5 Axis Jog-learn Spinning Lathes, 5 Axis Trunion Mills, Hydraulic Pipe Benders, CNC Saws 3-5 Axis, Six Axis Dual Spindle, Dual Y, Planer Mills, and other purpose build industrial machines.
• On site consulting, (international travel available)
• On site Training as well (will travel), for both users and OEM manufactures.
• HMI/PLC driven industrial machines as well using ADC PLC’s.
Notes:
At the "Mach3 CNC Convention S. E" we had about 80 people show, and ½ where OEMs from all over the Globe.
The 2nd Annual convention will be Feb 09.
S S Systems, LLC
1 (eight six five) 426-9728
PO Box 254
Briceville, TN 37710
Poppabear @ hughes.net (remove spaces around the @)
http://ss-systemsllc.com/default.aspx
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
Old 06-22-2008, 07:01 AM
Runner4404spd is on a distinguished road
do you guys do lathe systems as well as mill systems?
Old 06-22-2008, 07:33 AM
bobk is on a distinguished road
Poppabear10,
How would you compare Mach 3 to other programs such as Camsoft? I've looked at Mach 3 and just from what I've seen it seems to be more of a hobby system. I've been thinking of trying it, but wanted to hear from someone with extensive experience.
Old 06-23-2008, 08:34 AM
Runner4404spd:
Yes, Lathe systems are very do-able, I have done regular lathes as well as a custom 5 Axis joglearn spinning lathe.
bobk:
First I will say this:
CamSoft is a Major advertizer here on this site, and thus has alot of influence at the top, so I will say that the below is My Opion and from My Experiences.
I like Mach ALOT better for reasons to numerous to list, alot of the retrofits about 25% of the ones that I have done. Have been on machines that had CamSoft on them. The users where never able to get it to work right. Cam soft sits on a Galil motion card, and they (In my opion), still dont quite have it right.
Mach can and Does sit Very well on a Galil external motion card, as well as a Smooth Stepper. For a High End industrial Machine with high count encouders, I would recommend a Galil or a Smooth Stepper depending on your buget and the bells and whistles you want.
I am sure the sales, marketing and other guys from Cam soft will holler and screen about this, but I just look at it from a realistic end user/operators perspective. Ever Since Mach made a plug in to work with External Motion cards like the Galil, and Smooth Stepper. It just flat dominates any one else doing PC based CNC. Since the Galil is considered by all as an industrial card, then Mach or anyother PC based software, just becomes a way to interface with it.
Scott
Old 06-23-2008, 09:19 AM
Hello Scott,
Thanks for your responce. I'm asking these questions for my own research and do not wish to degrade any particular product. I have a Camsoft Pro version that I have not installed yet. Would you say that Mach 3 is as good or better than the Pro version of Camsoft? Can you give any reasons for your opinion? Thanks!
Old 06-23-2008, 10:10 AM
Scott,
i'm trying to use the Mach 3 lathe right now and i find it very cumbersome to program compare to the "professional software" the big issue revolving around lack of canned cycles, like roughing and boring, etc. do you guys have software written for this or will the mach 3 lathe setup still leave alot of hand coding. ultimately i don't mind hand coding if i can use my mastercam turning software to output to native Mach 3, do you know if anything like this is available as a post processor?
Old 06-23-2008, 11:27 AM
bobk:
I am not trying to degrade it eigther, I am just stating what I have personally seen and experienced. I have had service calls, and tried to get some of these machines working that had it on there, and no luck even contacting the vendor for tech support. So, just pulled it and replaced it, and that was that.
Runner4404spd:
www.novalabs.com
this guy has written several Post Processors for Mach3, he uses MasterCamX, and has post for 9 and X. He will also customize them for you for a fee, if you so desire.
The Lathe has a "Conversational" set of Wizards that will do most basic turning task.
here is the current canned cycle types according to the last published Turn doc:
Drilling types:
G73, G81, G82, G83, G83.1
Boring types:
G85, G86, G88, G89
Threading:
G32, G76
Roughing:
turn G77
face G78
These are the official ones, I think there are some more that have been added but the docs havent caught up yet. I will post them, when I find out.
scott
Old 09-01-2010, 10:26 AM
I have moved my website to:
http:\\www.SSsystemsLLC.com
Steve Stalling of PMDX was kind enought to host my old site,
while I was gone. Thanks Steve!! The new one still is getting
stuff added to it, so it is not totally all up yet.
got to figure out how to load up pics and vids from M$ Front Page,
man I hate website stuff..
scott
Old 09-03-2010, 04:47 AM
NZCNC is on a distinguished road
sounds great can you make contact
Tim
Old 09-03-2010, 07:59 AM
you can contact me here, or from on my site, or on my personal email:
poppabear"AT"hughes.net "AT", with @
scott
  #11   Ban this user!
Old 09-05-2010, 12:52 AM
Thumbs up
scott
Hi Scott not sure if you recieved my email as per your email Addy
Regards
Tim
  #12   Ban this user!
Old 09-05-2010, 09:19 PM
look on this site: www.SSsystemsLLC.com
on that site is my email, as well as a webiste contact email.
scott
Mach3 Full system integrator services avail.. PoppaBear10 Product Announcements & Manufacturer News 0 06-21-2008 11:19 AM
Turn off the system beep in Mach3? fatal-exception Mach Mill 0 09-19-2007 02:20 PM
Industrial Electrician Avail in SE Michigan ThomasAlva Employment Opportunity 0 04-23-2007 09:45 PM
commmercialy avail. 5 axi head tltaylor Commercial CNC Wood Routers 4 12-09-2004 01:09 AM
