Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-19-2008, 02:23 AM
timmydabull is on a distinguished road
RFQ mill and lathe work
i have 3 jobs that require a hardened material such as 4140 heat treat. i am not a metallurgist so i am new to steels and there variety,feel free to make suggestions.
part 1 .750 round button .175 thick.........36 pieces
part 2 .760 round button .175 thick .........24 pieces
part 3 arm .1875 thick,.882 wide,1.270 length ,..........36 pieces.
will provide solid files.
attached is a solid model mastercam x2 of each item
repeatable job needed ASAP (yesterday) will allow adequate ETD on future orders.
thank you for your assistance.
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
Old 06-19-2008, 02:41 AM
trying to upload files
ID:	61755   Click image for larger version
ID:	61756   Click image for larger version
Old 06-19-2008, 10:35 AM
KaesynCAM_Tech is on a distinguished road
4140 HT
Hello,
At what rockwell do you require these parts to be? Do you require them to be ground or hardmilled?
Old 06-19-2008, 11:18 AM
a milled finish is fine,these items are used in a centrifucal clutch setup so i would assume something close to tool steel or similiar.
i dont know much about Rockwell measurements but the piece i have in my hand a deburring tool will not scratch it.
thank you for your reply.
tim
Old 06-20-2008, 04:30 AM
doughtybrian is on a distinguished road
P M has been sent
Brian
Brian's Machine & Powdercoat
Old 06-20-2008, 12:28 PM
thank you for your quotes.
i have been asked for solid files and will post them here.
ID:	61831   Click image for larger version
ID:	61832   Click image for larger version
Old 06-20-2008, 03:48 PM
QUOTE HAS BEEN AWARDED CLOSED FOR BID>
i would like to thank those who took the time to provide us with a quote on this job,we have saved your contact information and will contact you in the future if theres something i can send your way.
once again thank you all very much for your time.
timmydabull
Waterjet, plasma, cnc mill, cnc lathe work Twil759 Employment Opportunity 0 09-18-2007 07:47 AM
RFQ - Lathe & Mill Work - Toronto/GTA ngr1 Employment Opportunity 1 07-15-2006 10:48 PM
RFQ for Two Piece Lathe & Mill Work stang5197 Employment Opportunity 3 02-20-2006 09:17 PM
Anyone want to do a little lathe/mill work? Cold Fusion Employment Opportunity 5 07-27-2005 01:07 PM
