| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Hi. I am looking for a quote on creating the attached drawing. If possible I would like a 4 pieces quote and a 8 pieces quote (they are to be used in a hobby project). The material used will be 6061 Aluminum (supplied by you). All sizes are measured using mm. The size of the space between the cooling fins are 1mm, if that is to small I can also accept a 2mm space. The sharp corners can be rounded, but the radius must be minimal. Last edited by snowcnc; 06-08-2008 at 11:41 AM. |
| Machining that part, though simple, would be expensive. Have you looked for a standard off the shelf heat sink that could be substituted? Heat sinks are typically extruded in large quantities, that keeps the cost down. |
| Need bid price for some simple aluminum pieces. | Crazy Phantom | Employment Opportunity | 14 | 11-27-2007 01:22 PM |
| RFQ - Aluminum "Stepped" Doughnuts. | 1972Chevelle | Employment Opportunity | 7 | 05-31-2007 06:17 AM |
| "Open Source" Aluminum Extrusion Profiles | devers6 | DIY-CNC Router Table Machines | 17 | 12-18-2005 05:04 AM |
| Question on "billet aluminum" | munkee | General Metal Working Machines | 1 | 09-28-2004 07:28 PM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
