Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-04-2008, 08:34 AM
millmonkey1 is on a distinguished road
Cnc Lathe Programming
Can you program a Fanuc controlled lathe in G-code? Can you teach somebody else? Are you in the Houston Texas area? Want to make some $ for your time or trouble? E-mail me. Thanks.
Old 06-04-2008, 07:44 PM
SeanC is on a distinguished road
I'm not near you but this might help you out if you're interested. I've read many good things about this guy.
http://home.columbus.rr.com/hputz/
-Sean
Old 06-04-2008, 07:50 PM
Arty 3000's Avatar
Arty 3000 is on a distinguished road
2 axes cnc lathe is very easy to learn. i would enroll in a trade school or community college. you need hands on training. it's ok to learn via CD or video to get the basics. but there is nothing like hands on. just my 2 cent.
Old 06-06-2008, 05:11 PM
Yeah, I know hand-on is best, but I thought I'd throw it out there.
-Sean
Old 02-04-2011, 05:03 AM
JayeshA is on a distinguished road
is there a web site which would teach you CNC programing of 2 axis lathe for free
Old 02-04-2011, 06:17 AM
LeeWay's Avatar
LeeWay is on a distinguished road
You can do basic simple stuff by jogging and logging.
In other words, just jog it and record depths and offsets of tools. Create multiple passes when needed. Learn a little bit about what the Gcode is.
You don't need to know all of it to do basic stuff.
I programmed 12 to 15 different brass bushing that I use for production without a drawing or a cam program.
Just used the edit code button in Mach 3.
Just do simple single axis moves.
I recently wanted to start turning profiles like chess pieces and things in the machines non production down time. Lots of that on this one. I use Dolphin Turn for the Cam. Works pretty well.
I would still have been in trouble had I not learned to program the basics by hand though.
On a lathe it is critical that you know what each axis is doing. Crashes can be deadly on a lathe. Even a small simple one.
Best would be a school or tutor session of course, but with a little patience and perseverance, you can do it without.
I am not familiar with Fanuc though, so don't know what the differences are between it and Mach 3.
Lee
Lathe programming mcm1961 Haas Lathes 2 07-19-2008 09:41 PM
Lathe: Synchronized C/X axis programming toastydeath General CNC (Mill and Lathe) Control Software (NC) 4 01-17-2008 08:58 AM
lathe programming learning ? pit202 Haas Lathes 13 11-23-2007 07:41 AM
c-axis programming lathe pjmorand G-Code Programing 8 10-05-2007 03:44 PM
Programming lathe with radius numbers mudwhump BobCad-Cam 1 06-07-2004 07:14 AM
