Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-28-2008, 12:32 PM
spydermeister is on a distinguished road
spacers for project
Hello,
I need a quote on these simple parts. about 90mm in diameter, see drawing.
19mm thick, mild steel.
4 of them
-Jim
Old 05-28-2008, 06:05 PM
Matt@RFR is on a distinguished road
What are the tolerances? Do the sharp corners in the ID of the part really need to be sharp? (Hint, if you want prices under $200/ea, those sharp corners need to be radiused)
Old 05-28-2008, 09:13 PM
DeAdNutS is on a distinguished road
you will need to find a shop with an EDM or raidus the intersect points of the 8.33mm raidus OD and ID and how about a parallel call out ?
Old 05-29-2008, 12:47 AM
What's a parallel call out?
Which corners are you referring to?
Basically the part is going to go between the cv joint and the stub axle in a project car.
Old 05-29-2008, 06:02 PM
parallel from one face to the other attached is a dwg file with a 1/4 Emill trying to cut the corners zoom in to see how a 1/4 Emill will leave a 1/8 inch raidus
Old 05-29-2008, 06:29 PM
cadman@teluspla is on a distinguished road
why not waterjet they get pretty accurate with good operator
Old 05-29-2008, 06:46 PM
Waterjet would work, I think.
Old 05-29-2008, 07:00 PM
waterjet or edm,waterjet would be best,edm will take more time, but if you dont have clearance problems the strongest way would be to put a raidus in and have them milled on a 5 axis lathe
My little project Pyrotechnical Plasma, EDM and other similar machine Project Log 37 08-31-2008 04:11 PM
First cnc project chester1957 Stepper Motors and Drives 1 01-04-2008 08:59 AM
NSK Rails - Replacement balls and spacers? Lionclaw Linear and Rotary Motion 4 02-24-2007 01:36 PM
47mm bearing spacers N4NV Linear and Rotary Motion 5 02-06-2007 07:40 AM
RFQ - Aluminum plate and spacers tjstraz Employment Opportunity 3 01-26-2005 08:25 PM
