Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-27-2008, 12:40 AM
turbodime is on a distinguished road
Aluminum parts
The parts will be made out of 3/4" 6061-T6 I can supply if needed.
The two threaded holes need to be drilled with a "G" bit and tapped with 1/4"-28 STI tap for helical inserts.
Aaron
ID:	60309   Click image for larger version
ID:	60310   Click image for larger version
ID:	60311   Click image for larger version
ID:	60313   Click image for larger version
ID:	60314   Click image for larger version
ID:	60315   Click image for larger version
Aaron
Mesa,AZ
Old 05-27-2008, 05:21 AM
Runner4404spd is on a distinguished road
how many do you need? when do you need them?
Old 05-27-2008, 08:44 AM
25 of each. In two weeks. Whoever gets the job there will be a need for more in the future. I just put 25 down to get me a ballpark figure.
Aaron
Mesa,AZ
Old 05-27-2008, 09:01 AM
Philip is on a distinguished road
PM sent with quote
Aaron,
PM sent with quote. Thanks.
Regards,
Philip Confalone
PC Machine Works
Philip Confalone
Machining Concepts
Old 05-27-2008, 04:50 PM
Dualkit is on a distinguished road
I am assuming your 2 threaded holes are on the same part, which looks like one hole completely through
the side of the 4" long part. Also how about tolerances?, it
amazes me how many people give out quotes without knowing tolerances.
I could not imagine somebody charging the same to hold .0001s instead of +/- .005, or is that the norm these days?,........Bob
Old 05-27-2008, 06:07 PM
on these type of quotes with no formal drawings we assume +/-.005 to quote and try and work with the customer.
Old 05-27-2008, 09:58 PM
Tolerances
Bob,
The typical tolerance would be .0 +/-.015" .00 +/-.010" .000 +/-.005"
Looking at the picture of the part I think it's safe for one to assume tolerances are not that tight. I may be proven wrong shortly, but that's how I quoted.
Regards,
Philip Confalone
PC Machine Works
Philip Confalone
Machining Concepts
Old 05-28-2008, 12:13 AM
In my haste in trying to get the drawing out I forgot two critical points; tolerances and the 5/16" hole depth.
The 5/16" hole depth is 1.75".
Most people that have quoted me have given tolerances of +0.005/-0.005 this will be fine for all the specs but the .3125 hole. This need to be +0.005/-0.000.
Your right on the rough part in the pic's. I made 150 of these on my '39 Sheldon lathe.
I'm jobbing this part out to tighten up the tol's and to free up my time.
Thanks to all those that have quoted the part and will be giving the job tomorrow afternoon.
Aaron
Mesa,AZ
Old 05-28-2008, 04:49 AM
doughtybrian is on a distinguished road
P M has been sent
Thanks Brian
Old 05-29-2008, 03:50 PM
The quote is closed and the job has been awarded. Thanks to all for quoting on the job.
Aaron
Mesa,AZ
RFQ for Aluminum parts Boundary Employment Opportunity 3 11-13-2007 09:44 AM
RFQ - Aluminum Parts - small job F500 Employment Opportunity 8 06-08-2007 03:30 PM
RFQ: Aluminum BB cannon parts Greg McFadden Employment Opportunity 7 05-17-2007 09:35 AM
RFQ for some Aluminum Computer parts Compufobia Employment Opportunity 8 11-10-2005 03:18 PM
RFQ - Aluminum Parts Joe_CNC Employment Opportunity 11 01-19-2005 03:07 AM
