Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-12-2008, 08:00 PM
fastolds is on a distinguished road
RFQ for simple aluminum job
I would like quotes on the attached file and turn around time. Please email them to hobbymachine at mchsi dot com Thanks!!
Old 05-15-2008, 05:40 AM
mdred68 is on a distinguished road
what kind of tolerances are required any critical areas?
Old 05-16-2008, 10:42 AM
Philip is on a distinguished road
Simple aluminum job
Has this job been awarded? Thank you.
Philip Confalone
Machining Concepts
Old 05-18-2008, 09:03 AM
Thank you for all the quotes. I will going over them.
For your reference:
This is a simple part with +/- .005 tolerence that I machine in under 10 minutes in 2 setups.
First side is the 4 holes and counterbore, second side I cut the outside and step on a fixture.
I pay less than a $1 for material.
A few of the quotes I received were close to $20/piece. If I could charge the customer that I would do them.
Anyway, thank you.
Old 05-18-2008, 10:11 AM
Rfq
I guess the answer to my question would be no? Thanks.
Philip Confalone
Machining Concepts
Old 05-18-2008, 12:51 PM
Matt@RFR is on a distinguished road
Robert, did you not get my email? My quote is quite a bit less than $20/ea.
Old 05-19-2008, 05:42 PM
SeanC is on a distinguished road
Hmm...
I also was way under $20/pc.
-Sean
Old 05-20-2008, 07:08 AM
Runner4404spd is on a distinguished road
my quote was well under $20 as well
Old 05-21-2008, 06:16 PM
Yes I received all the quotes and thank you all for your time. This job has been awarded.
Old 05-21-2008, 06:27 PM
Can you post what the winning bid was and the time time frame of the delivery?
  #11   Ban this user!
Old 05-26-2008, 09:04 PM
I won't post the winning bid but will say it was way under $10. About a 1 1/2 weeks to get.
Need A Quote- Simple T6061 Aluminum Frame sleepy23 Employment Opportunity 1 05-15-2008 05:45 AM
Need bid price for some simple aluminum pieces. Crazy Phantom Employment Opportunity 14 11-27-2007 01:22 PM
Simple Aluminum Part vadimvc Employment Opportunity 3 04-30-2007 03:51 PM
Simple Aluminum Lathe Work stang5197 Employment Opportunity 7 09-28-2006 09:03 PM
RFQ Simple Aluminum Bearing Blocks b0gh0s Employment Opportunity 8 12-23-2004 03:57 PM
