Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-08-2008, 04:46 PM
dcorbett is on a distinguished road
Fiberglass "washer"
Hello,
I have been watching in the wings for a while now, and am very impressed with the collective knowledge.
I need 60 fiberglass "washers" made (close description, though a it more complex), somewhere close to 1/8" thick.
Is there anyone interested in quoting these parts?
Thanks.
Old 05-21-2008, 10:22 AM
Rapid Tech is on a distinguished road
Hello,
Is this quote still open? What are the tolerances?
I did a search for the material, it showed up as G-10 fiberglass.
Is this correct?
Old 05-21-2008, 01:29 PM
Tolerances
Yes, the quote is still open. I have not received any yet, though numerous questions. I will attempt to remedy the lack of information in this reply.
1) The material is stated only as "fiberglass", prefer a weave (not random mat) there are no other constraints.
2) Tolerances are fairly wide open. The only two critical dimensions are the OD (+.000"/-.010"), and the small holes (+/-.002").
Otherwise, the tolerance on the depth of the "channel" is +/-.015", the ID of the hole through the middle is .250" +.020/-.005"
The material thickness is .125" +/-.015"
Did I leave any out?
Thanks for all your questions.
Old 05-21-2008, 11:18 PM
Monte is on a distinguished road
Another G-10 part rfq. I need to cut some of this stuff and see how it cuts. Me thinks it'll be nasty.
Monte
Old 05-22-2008, 10:12 AM
Philip is on a distinguished road
Washers
Sent you a PM.
Philip Confalone
Machining Concepts
Old 05-27-2008, 01:38 PM
Washers
Have you awarded this job? I received no response to my email I sent. Thank you.
Regards,
Philip Confalone
PC Machine Works
Philip Confalone
Machining Concepts
Has anyone tried fiberglass? Tom Brown Open Source CNC Machine Designs 39 03-09-2009 06:24 PM
Cutting fiberglass inertialabs Laser Engraving & Cutting Machines 4 05-21-2008 01:34 PM
Need Help!- What material to use for fiberglass lay-ups??? animuL Composites, Exotic Metals etc 2 04-23-2008 08:40 PM
Fiberglass Canopy ShortRunCNC Parts for Radio Control Models 6 05-22-2007 03:02 PM
polyurthene vs fiberglass pyroracing85 General Material Machining Solutions 7 02-11-2005 11:53 AM
