Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-02-2008, 05:29 PM
43220 is on a distinguished road
RFQ
A - cylinder, steel or AL, .870 o.d. dia x 3/4" long with 1/8" center hole drilled thru.
B - cylinder, steel or AL, 1" o.d. x 3/4" long with 1/8" center hole drilled thru.
Normal machining tolerances and finish OK. B can be from standard 1" bar stock.
Quote one each (proto for approval) and 6 & 12 each.
Old 05-02-2008, 06:14 PM
Also need one (note - change i.d. from 1.004 to 1.000, and 1/4 shaft to 3/8) - sorry for crude sketch!
Old 05-06-2008, 06:00 PM
doughtybrian is on a distinguished road
Part A 1pc. @ 12.50 6pcs @ 11.00 ea. 12pcs @ 9.99 ea.
Part B 1pc. @ 10.00 6pcs @ 9.00 ea. 12pcs. @ 8.00 ea.
Stainless part per sketch 1pc. @ 25.00 6pcs. @ 23.00 ea. 12pcs @ 21.50 ea
Thanks Brian
Old 05-16-2008, 04:48 PM
Metal Man is on a distinguished road
What kind of tolerances do you have on the stainless piece?
Old 05-16-2008, 05:26 PM
Never mind - project cancelled.
