| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Looking to get a quote for 50 spacer plates machined from 6061-T6 Alum. Thickness 10mm. Also 50 spacers at 15mm thick. Grand total of 100 spacers. I would like to have them by May 16. No plating required. Tumble deburr ok, or just a machined finish is fine. The only critical dimensions are basically the thickness and that the two flat surfaces be parallel within .001 The outside contour is not functional, just designed for clearance and looks. + or - .010 A semi fast machined surface is acceptable,(facemill) just as long as all 100 parts are identical in appearance, thickness and parallelism. I can supply a solidworks model or mastercam file of this part if needed. Thanks. |
cncharleydude: Please submit to me your desired price point for the total project (100 spacers) and I will notify you if I am able to produce them. Time constraints are not a problem at this time. Thanks, Bob Bagley, Hoosier Machine Shop
| RFQ-50 spacer plates needed | cncharleydude | Employment Opportunity | 8 | 12-20-2007 07:21 PM |
| RFQ - Need spacer made | Runner4404spd | Employment Opportunity | 14 | 12-13-2007 11:00 PM |
| So I've got this air-indexer... Cushman Air Flash Super Spacer. | ralph@nes | General Metal Working Machines | 0 | 06-25-2007 03:50 PM |
| WTB 12" Super Spacer | Fudd | General Metal Working Machines | 0 | 07-14-2006 03:43 PM |
| Super Spacer | Zumba | General Metal Working Machines | 5 | 03-21-2006 07:08 PM |
