Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 04-29-2008, 01:13 AM
FloridaNewBe is on a distinguished road
CNC Machine + Manual Tool Operator Needed - Weston, Florida
We are looking for an experienced CNC operator to set-up and utilize our new ShopSabre CNC machine.
We have VCarvePro and VisualMill installed. We need you to take our current hand built machines, and setup the cuts to produce identical parts for all our model variations using the appropiate software.
You will be cutting steel using the CNC's plasma cutter, as well as plastic and wood useing a lathe.
We are looking for an experienced CNC machininest that can QUICKLY program and utilize our new machine to produce all variations needed.
Additionally, the idea candidate will have knowledge of metal work and be able to tig/mig weld, use a handheld plasma cutter, spot welder, neumatic tools like shears and saws, as well as ability to operate a hand break/shear and tube/pipe bender roller.
Experience in electrical is a major plus as well.
Description/Requirements
• Must be able to complete machining operations from existing products or verbal instructions
• Must have experience with complex, tight tolerance parts and various materials like wood, metal and plastic
• Experience in machine shops skills such as welding, drilling, and traditional manual hand tools are essential
• 3+ years actual machining experience desired
• Visual Mill + Carve Pro Experience is REQUIRED
• Ability to perform basic math functions, including decimals and fractions
• Use measuring tools, devices and equipment such as scales, calipers, micrometers
• Proficient in the use of fabrication equipment such as tube bender, notcher machine, tig/mig welding, drill press, metal shear, metal brake is a plus
• Works from existing products or verbal instructions
• Fabricate, assemble, install, and test units before shipping with little or no supervision
• Perform duties in other skill areas such as electrical, and metal part fabrication is a huge plus.
This position is located in Weston, Fl. If you are interested please email your resume w/ work experience and contact information to howardbirnbaum696@hotmail.com
THIS IS FOR AN IMMEDIATE OPENING! MULTIPLE POSITIONS AVAILABLE.
Old 04-30-2008, 02:55 AM
Forgot to mension. Very good pay in an easy going environment. Flexible hours and good people. This job is a lot of fun. Email me for more information and please forward your resume if interested...
IMMEDIATE OPENINGS!!!
Old 11-16-2010, 03:19 AM
hdblue is on a distinguished road
Thanks very much for this comment. It help me to think about my ideals.
Tks again and pls keep posting
Old 11-20-2010, 07:25 AM
Originally Posted by hdblue View Post
This link below can show more info, you can find them at: Welding job descriptions
Old 12-23-2011, 06:47 AM
kerryjennings11 is on a distinguished road
Thanks for providing valuable link on this forum.
I want to give you 1 valuable link which is veryuseful for career.
visit: Job Descriptions
Need Help!- Need Operator manual areofab Want To Buy...Need help! 1 11-07-2008 02:43 AM
Meldas MO operator manual cut more Mazak, Mitsubishi, Mazatrol 44 08-12-2008 01:15 PM
Acramatic 850 operator and programming manual buckie555 General CNC (Mill and Lathe) Control Software (NC) 1 06-02-2008 07:13 PM
Hitachi HT20 Operator Manual needed, will pay! 80spit General Metalwork Discussion 0 07-08-2007 08:48 AM
Cnc/manual Operator & Programmer In North Nj elaganis Employment Opportunity 0 08-02-2006 08:17 PM
