Results 1 to 8 of 8
Thread: RFQ - Completed - thanks to all interested
    Apr 2003
    I have a need for 2 aluminum plates with 6mm and 10mm milling and tapping. Some notes:
    The drawings show these plates as 10mm thick but 1/4" can be used if you can tap 6mm in the side of it. I have attached Rhino 3dm but I can provide other formats. You provide the material since I want it yesterday. Tolerances are to within .005" even though the drawing is in metric units.
    Attached Files Attached Files
    Site Owner CNCadmin's Avatar
    Mar 2003
    can you post in dwg ?
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Apr 2003
    DWG Post
    I don't usually have much luck with autocad but here it is:
    Release 2000 (have others)
    curves as polylines
    surfaces as polygon meshes
    Apr 2003
    Much better dwg
    I think these are much better.
    Curves as splines
    Surfaces as curves
    w/ 3d faces
    Gold Member
    Apr 2003
    Ohio, USA
    My cad hates Autocad 2000 dwgs
    You may want to go to .5 plate if possible, 1/4" = .25, 6mm=.236 so that wont float, 3/8" is really on the skinny side as well.It would make life simpler to convert to imperial.
    Edit:
    Where you located?
    Ken
    Apr 2003
    Version 12 DWG
    Here they are in Release 12. I have others.
    Gold Member
    Apr 2003
    Ohio, USA
    You did not respond to the conversion to imperial suggestion, for .5 plate or where you are from, if you get together with someone this will be important.
    Ken
    Apr 2003
    More information
    I am from Clermont, Florida 34711. The drawing may be changed to imperial and you may use .5" plate. The slots and other features must still adhere to the .005" tolerance from the drawing, including the error for the imperial conversion.
    1. Interested? in milling a logo in aluminum for $$$?
      By midevilone in forum Employment Opportunity
      Last Post: 04-13-2005, 01:49 AM
    2. RFQ - small al. parts - Completed
      By kdoney in forum Employment Opportunity
      Last Post: 04-11-2005, 05:16 PM
    3. Posting RFQ
      By CNCadmin in forum RFQ (Request for Quote)
      Last Post: 11-03-2004, 11:57 PM
    4. RFQ closed - scale model machined auto wheels needed
      By joemartins in forum Employment Opportunity
      Last Post: 10-27-2004, 09:16 AM
    5. Interested in NY/NJ CNC machine demo...
      By jasonsp6 in forum General Metal Working Machines
      Last Post: 07-23-2004, 01:47 AM
