| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I've attached two dxf files that show a worm gear and a worm drive. I'm looking for quantity two of each for now. This is a new product that I am working on and if it pans out there would be requests for more. I will take suggestions on material. I've spec'd. 1018 for the worm drive and gear bronze for the worm gear. Private email me at "lewenz@sbcglobal.net" with quotes / questions. There is no rush at this time as I am very busy with other projects. I'd like to see all quotes to me by 5/2/08. Thanks P.S. had to zip the worm gear dxf file as it was too big to upload. |
| LEWENZ, I think you'll want a steel that can be hardened better than 1018. Also, you'll need a fine finish on the worm to avoid "eating" the worm gear. Have you investigated Boston Gear or Martin Sprocket/Gear for an available set? Or better yet, Cone drive for full enveloping worm/worm gear sets? Just a thought. Dick Z
__________________ DZASTR |
| LEWENZ, I looked up www.bostongear.com open gear catalog. There's a good engineering section that includes worm gearing info. I also copied your prints. The dimensions don't appear standard stuff. Just for jollies, look at 24 DP 72 teeth. I believe you're working on some rotary devices. If so, are your requirements for a given ratio, center distance or ? Maybe I can help. BTW, I live near Milwaukee. (your "about me" says you do as well ). Dick Z
| Zero backlash worm gear idea. | ynneb | Mechanical Calculations/Engineering Design | 14 | 07-31-2009 01:25 PM |
| Need Help!- Worm Gear | jackson | General Metalwork Discussion | 1 | 02-07-2008 04:25 PM |
| worm gear drive | csrc | DIY-CNC Router Table Machines | 5 | 07-03-2007 03:53 PM |
| Ha5c Worm Gear | engine tech art | Haas Mills | 8 | 05-09-2007 09:08 PM |
| Worm gear hobbing question | Dfennell | General Metalwork Discussion | 3 | 02-01-2007 07:48 PM |
