| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
Hello, I need 3 shaft couplers that go from 1/2" to 3/4". Bore A: 3/4" Bore B: 1/2" Outter diameter: 1 1/2" Length: 2 1/2" Material: 6061 Aluminum The depth of each bore should be equal, meaning 1 1/4" for each one, nothing special needs to happen in the middle. I plan to drill and tape the set screws for this, so no need to worry about that. Tolerances should be pretty tight, although i'm not Nasa or anything. Obviously this should be done on a lathe, i tried doing this myself with machineable-bore couplers from mcmaster, and using a drill press, but they are off a tiny bit and make the machine do horrible things, so I need to them to be made well. Or if someone knows where to buy these, I can't for the life of me find any supplier that has these, most only step 1/8" of an inch, not a 1/4". thanks, Ross |
| I did not mean step as in how much to step your lathe, i just meant that the diameter bore difference is generally at most an eighth of an inch (at mcmaster and others). It states very clearly that I want Bore A to be 3/4" and Bore B to be 1/2", there should be no other interpretation |
| Mcmaster part # 6208K243 Bore A: 3/4" Bore B: 1/2" Outter diameter: 1 3/4" Length: 2 3/4" Material: Aluminum $52.04 each part 6507K3 will also do 1/2 to 3/4 Both of these are flexible couplings, it looks like you need one bored out if you have to have a rigid coupling. Regards Matt Last edited by keebler303; 04-17-2008 at 03:53 PM. Reason: added |
| Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft | DonW | DIY-CNC Router Table Machines | 7 | 03-17-2008 04:58 PM |
| Home made shaft couplers | EL34 | DIY-CNC Router Table Machines | 8 | 09-25-2007 04:47 AM |
| shaft couplers | dgalaxy | Benchtop Machines | 4 | 02-01-2006 12:18 PM |
| Good Shaft couplers | klick0 | General Metalwork Discussion | 5 | 01-01-2006 09:23 AM |
| shaft couplers do i need | craftech | DIY-CNC Router Table Machines | 3 | 11-29-2004 10:26 AM |
