Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 04-08-2008, 09:03 PM
alexccmeister is on a distinguished road
Need to fabricate a large steel plate with designs.
Hi all,
I haven't posted here for a while. But I have an opportunity to do a job for a client that is looking to have a large piece of 8mm thick marine grade stainless steel plate cut into a certain shape. The steel plate itself have designs cut into the middle. Its for a commemorative monument our client is doing.
Basically, my request is, does anyone know a few companies that can do laser/plasma CNC cutting of MARINE GRADE stainless steel? The completed panel size of the steel plate is roughly 6m x 15m. I need two made. One is mirror image of the other. Basically I need a quote to submit to my client. I can post a pic as soon as I get the design from my client. The plates can be made in section and then welded when they arrive to site. Please help if anyone here can. Thanks.
Alex
Old 04-08-2008, 09:11 PM
kb0thn is on a distinguished road
Try rfqwork.com
You might try rfqwork.com. My company has put a couple of parts up there and gotten very good response from many shops.
Also, waterjet might be a better way of cutting your plate.
Old 04-08-2008, 09:14 PM
Med-Pac is on a distinguished road
quote request
Good evening Alex,
We would be interested in your project. Our plasma table is 4' x 8', I can index to 16' on the x axis but we're limited to the 4' width. Would that work for you? How thick were you going to make this?
Give me a send me an email at mbraaten@med-pac.net, we have a knack for these type of projects.
Regards,
Mike Braaten
Old 04-08-2008, 09:38 PM
Hi kb0thn,
Thanks for the info. Does waterjet cutting do a better job over plasma? I need the finished product to be nice and straight cut and as little flaw as possible. Will check out rfqwork.com. Thanks.
Originally Posted by Med-Pac View Post
Good evening Alex,
Regards,
Mike Braaten
Hi Mike,
I have emailed you. Please check your mail. Thanks.
Alex
Old 04-08-2008, 09:44 PM
plasma vs waterjet
In general waterjet will hold better tolerances and make a nicer finish than plasma. For thin material it may not matter. But when you get in to very thick material waterjet will definitely be the way to go. Waterjets can basically handle any thickness material just by altering their feed rate. With plasma as you go thicker you need a bigger and bigger machine. Almost any waterjet can cut 5"+ thick material. There are multi-axis waterjets that will account for taper of the jet as well.
You can learn about waterjet cutting at: http://waterjets.org/ (not affiliated)
Old 04-09-2008, 12:09 AM
Thanks for the info. Will check out the site.
Machine Large Alu Plate for CNC router wfung General Metalwork Discussion 6 12-11-2007 05:07 PM
Surfacing Steel Plate Hibo Tormach PCNC 2 10-22-2007 01:55 AM
Seeking steel plate mfr. browniecrystal Employment Opportunity 2 10-21-2007 09:55 PM
large teflon plate juzwuz CNCzone Club House 2 10-14-2006 07:21 PM
Cutting Large Diameter Holes in Aluminum Plate barkster General Metal Working Machines 18 04-07-2004 06:44 AM
