| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I also have time available. Send details to auntmillies@zoominternet.net, or call 1-814-336-8554 ask for Al, if you are still looking for someone to help you with this. Regards, Al Dixon |
| Size is 1/4 x 26 x 27. Is a decorative grid pattern cut 1/4" deep (thru) across entire surface. Program router to cut and repeat over and over several hundred times until entire piece is routed. I will provide grid design/pattern info. Plastic may be desirable (if will hold up better) unless prohibitively costly compared to hardboard. Color should be a brown or black or can easily be painted same. Last edited by 43220; 03-31-2008 at 09:47 AM. |
| I don't know that hardboard or plastic would be suitable for something like that. I would suggest aluminum or stainless. If either aluminum or stainless will work for you, I can laser cut it. I can laser cut acrylic as well, and probably a lot faster than it can be routed and the edges are as clean as flame polished surfaces. Gary |
| I also have time available. Send details to h2precision@aol.com, or call 1-408-441-8758ask for Hieu, if you are still looking for someone to help you with this. How about using the black ABS Regards, Hieu |
#10
#11
| looks to be black delrin, which is stiff, and can be cut at high IPM speed, with that dimension, it can be done in under 10 minutes on a multicam router 5000 series. actually a 4x8 sheet could be done in about 30 minutes or less with tolerance approaching .005 or better. what type of finish are you looking for? |
| Newbie- Part holding and milling 3D part on 2.5D Mill? | john_t_h | General Metalwork Discussion | 6 | 03-15-2008 07:35 AM |
| RFQ 6 copies, milled part, 9 copies turned part | sswitaj | Employment Opportunity | 5 | 01-31-2008 02:42 PM |
| Missing steps on just a certain part of the part | ZipSnipe | Stepper Motors and Drives | 5 | 01-02-2008 02:40 PM |
| wood help | JoSh.ExE | WoodWorking | 3 | 03-06-2006 02:38 AM |
| Not Wood but works like wood almost | foamcutter | WoodWorking | 8 | 07-12-2005 05:14 PM |
