Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: 50 000 parts fitting in your one hand
    Sep 2006
    Estonia
    If got your attention:
    I am looking for a supplier for the parts, material is 1.4301/AISI 304, parts are described in attached drawings. Production quantities start at 1000 parts, yearly need is around 60 000 each. Validation and qualification samples are mandatory. If you have anything to clarify, feel free to ask.
    To avoid previous pitfalls at the start:
    *Tolerances are metric
    *The radii are correct, 0.02 is maximum allowed
    *Parts have to be concentric
    Attached Thumbnails Attached Thumbnails 50 000 parts fitting in your one hand-nten_048.jpg   50 000 parts fitting in your one hand-nten_049.jpg
    550nm
    Registered zedzero's Avatar
    Apr 2006
    Tricky little job....just interested,how do you check the .02 internal radius
    Mar 2008
    My guess would be an optical comparitor. A tricky job indeed.
    Sep 2006
    Estonia
    Quote Originally Posted by Rapid Tech View Post
    Correct - the first test is optical compare. The main problem is that the assembly loses critical function if radii tolerance is not met.
    550nm
    Gold Member
    Dec 2004
    Newtown, CT, USA
    Is an undercut acceptable?
    Instead of the small radius? I wouldn't think that would impact the function.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Dec 2007
    Ron
    Ron Smith
    "The Cyber Shop"
    1424 Kansas Lane
    Gallatin, TN 37066
    Phone: (615) 772-7990
    Sep 2006
    Hi, I would think that the quantity and tolerances involved would lend itself to sintering.
    Ian.
    Sep 2006
    Estonia
    Unfortunately even small undercut can be cause of unwanted effects in assembled device. Modifications to the parts are not acceptable at the moment.
    Quote Originally Posted by CNCDesk View Post
    Ron
    550nm
    Sep 2006
    Estonia
    Quote Originally Posted by handlewanker View Post
    Ian.
    Sintering is an interesting option for micro manufacturing; I am not familiar with the current sintering possibilities. What I have found, is that lots should be bigger to be cost effective - monthly volumes around 100 000.
    Also offered raw surface finish seems to be close but not enough without secondary smoothing operation. In addition to that there are ejector marks, differences related to stress tolerance and wearing.
    550nm
    Sep 2006
    Hi tr2, know what you mean, but when the desire outstrips the ability to satisfy the customer's needs, then it's back to the drawing board to modify until you can.
    I was taught this by the chief mechanical draughsman in our drawing office, and it was a rule that he applied to all would be design engineers who made drawings of things that could not be made.
    This concept was also applied to some of the designs of parts supplied by Rolls Royce at a firm I worked for in the UK in the '70s, and there were many modifications that otherwise would have made manufacture an impossibility.
    At my last employ, before I retired, we had stainless steel sintered parts made that were vibro finished to give the surface finish required, as the volumes exceeded many thousand parts per week.
    Ian.
    May 2007
    Yeah, been times I would loved to have some of these engineers make parts per their own drawings.
    May 2006
    china
    Smile
    Quote Originally Posted by Tr2sa View Post
    You can try automatic lathe machine that is used to make electricity plug pins. If qty is real, this can be made less than 0.10usd/pc. I do not have this machine but I can help if you are interested. My email is sumomoto@gmail dot com
  • Page 1 of 2 12 LastLast
    1. Banjo Fitting
      By jackson in forum General Metalwork Discussion
      Last Post: 09-27-2007, 11:16 AM
    2. Re-fitting a mill
      By gunner312 in forum Benchtop Machines
      Last Post: 07-11-2007, 10:31 AM
    3. cnc fitting a bridgeport
      By MBG in forum Bridgeport and Hardinge Mills
      Last Post: 09-26-2005, 05:25 PM
    4. What spare parts to keep on hand?
      By DAB_Design in forum Benchtop Machines
      Last Post: 02-16-2005, 01:56 PM
    5. coverting from Right-hand to left-hand coordinate system
      By eltonr in forum General CAM Discussion
      Last Post: 10-14-2004, 09:40 PM
