Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-09-2008, 02:23 PM
DSL PWR is on a distinguished road
Job has been awarded
Please quote these pieces in lots of:
50 sets, and 100 sets
Material: 1018, or 1040, or 1045 (your choice)
Please break out lathe, and mill work, as I may do the mill work (drill and tap)
1/4-20 holes shall be chamfered 45deg .26" dia
1/4" thru holes shall be debured.
1/4-18 NPT shall have a min chamfer of .01"
The finish shall be smooth, and burr free.
Shipping to Edmonton AB (dock), and Ft. Nelson BC (dock)
1 sample must be shipped with in 5 working days of the job being awarded to Ft. Nelson BC, and a tracking number provided. Once the parts pass inspection, the order will happen with in 5 working days. Once the production order is placed it should ship with in 10 working days.
I look forward to getting this production run done as my prototypes have passed testing, and I am ready to go to market.
This quote will close on Mar. 16 2008
Carl.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 03-09-2008, 07:05 PM
Derek.C is on a distinguished road
Looks like good work
Looks like it can be a good job but you will need to break the dimension lines off the part in the print so I can tell where the part ends and the dimension lines start .
Old 03-09-2008, 07:08 PM
I layered the dimension lines in the print, just turn them off and on as needed.
Old 03-09-2008, 07:16 PM
Sorry guy but I only get one layer for your print .
Old 03-09-2008, 07:34 PM
Here it is less the dimensions
Aluminum multi axis part needed--CLOSED--AWARDED silverfoxx03 Employment Opportunity 5 12-07-2007 03:07 PM
AWARDED ---1000 pieces - Easy part THANK YOU ALL pedroman Employment Opportunity 8 10-18-2007 02:52 PM
Rfq Acrylic Casing For Electronics (Awarded) naspc Employment Opportunity 26 05-30-2007 05:49 PM
RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED - JavaDog Employment Opportunity 6 11-17-2005 03:25 PM
